06-24-2018, 10:44 AM
Why even bother with a 3/4 ton truck?
There seem to be some universal truths in the RV community. One of those is that most people will almost always upgrade their RV's to a larger and heavier camper. Another almost universal truth seems like you should buy as much truck as you can afford.
I laughed years ago when a full-timer told me I would get a new RV every 2-3 years that was at least 3 feet longer than the last one. Guess what, he was right. I think we are up to our 5th RV and as soon as our truck is paid off in 35 months, will upgrade from our 30 footer to a 33-35 ft 5th wheel.
Anyway, I digress.
My question is, Why do people bother buying a 3/4 ton truck when you can get greater payload and possibly tow rating capacity with a 1 ton truck?
My experience showed that you could get a 1 ton truck for the same money as a 3/4 ton truck and sometimes less because of the "stigma" associated with 1 tons (poor and harsh ride unloaded).
I see, read, and hear a lot of people upgrading their 3/4 ton trucks with airbags in order to increase payload when they do upgrade even though they are not "legal" to carry a heavier load.
As for ride? I put a very heavy Curt 24k 5th wheel hitch in my F350's bed. Couple that with about 500lbs of water and gas hauled in the bed most of the time, I don't really notice a difference between the F350 and F250 trucks.
06-24-2018, 10:48 AM
This must have been posted by a troll!
No other comment needed.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
06-24-2018, 10:54 AM
My guess is:
1. Its often the buyer's first heavy duty truck purchase so a 3/4 ton seems like more than enough for anything they'll ever need.
2. There are typically 5-10 times as many 3/4 tons on the lot as there are 1 tons. With that big of a selection, the buyer is far more able to find "his" truck among the 3/4 tons.
06-24-2018, 10:59 AM
I don't know anything about the troll part, but the content is not totally without merit. There is more than one person with a 3/4 ton that would be better served with a bigger truck. Even with the trailer they had when they bought the 3/4 ton!
2017 Riverstone 38FB Legacy
2018 F450
06-24-2018, 11:00 AM
Georgia Rally Coordinator
Two ways to look at this. First I always bought a 3500 truck just in case. Well now that I'm down the road several years and older now the 2nd option is the 2500 truck. No longer need the 3500 as now towing less of a camper. And yep my new 2500 truck has the air ride supension and rides nice. Adding air bags does not increase payload either. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-24-2018, 11:44 AM
Not trolling, just curious. I went from a F150 Platinum to a F350 Platinum to "be done with it".
I know that airbags do not increase payload capacity but there appear to be quite a bit of folks adding airbags to haul RVs that exceed their stickered payload capacities.
I have a neighbor who purchased a 40' 6" foot Jayco that had a tongue weight approximately 340 lbs shy of his caargo capacity rating unloaded. He has a wife, 2 kids, and a dog that tag along ;-)
A year later, this neighbor is now towing the same fiver with a dually. He must have figured out that he was overweight.
Still got a neighbor who is towing a 34 foot travel trailer with an F150 with no factory tow package no tow mirrors but that is another story.
By no means, am I "weight police". I towed a 5500 lb loaded 26 footer with my diesel Jeep Grand Cherokee for years. It did just fine with no white knuckle experiences and was only slightly over my cargo carrying capacity with my dog inside.
06-24-2018, 12:24 PM
In many cases, SRA 1 tons are very similar in ratings to 3/4 tons from the same OEM. Not nearly the range of difference as 3/4 tons are to 1/2 tons.
06-24-2018, 12:43 PM
Many states heavily tax a truck over 10k GVWR even for non commercial. That’s the reason.
06-24-2018, 12:51 PM
SRW (Single Rear Wheel) 3/4-ton vs 1-ton difference can be substantial.
Ford:
F-250 CCSB 4x4 6.7L - Max payload 1,836LB
F-350 CCSB 4x4 SRW 6.7L - Max payload 3,117LB, an increase of almost 1,300LB over the F-250.
GM:
2500HD CCSB 4x4 DMAX - Max payload 2,513LB
3500HD CCSB 4x4 SRW DMAX - Max payload 3,927, an increase of just over 1,400LB
Ram:
2500 CCSB 4x4 6.7L - Max payload 2,318LB
3500 CCSB 4x4 SRW 6.7L - Max payload 4,020LB, an increase of just over 1,700LB
I wouldn't call those similar payload capacities at all.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
06-24-2018, 12:57 PM
For me it was the better selection of 3/4 ton trucks when I was shopping. It is licensed for 9500 GVWR so the plates are only expensive (vs exorbitant). I do not anticipate the need for anything larger. I do not pull a 5th wheel because I load my Goldwing into the bed of the truck when we go on extended trips. Even with a 1000# bike in the bed while towing, it is not overloaded.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
06-24-2018, 01:00 PM
All i know is i rather have someone behind me towing with 1 ton truck if there is an emergency and we have to stop quickly.
I got the 2500 because the color I wanted was not available for the 3500 for ten months.
BIRDS AREN’T REAL
06-24-2018, 01:18 PM
Ford:
GM:
Ram:
And all you quoe are diesels. Just got a new Ram 2500 6.4 gas max payload 3331 and not a 4x4. And good options. Lter RJD
Days camped 2019 62
06-24-2018, 01:25 PM
TBarbs
I recently priced out a F-250 against a F-350 with the same options and it was a little over $1100 difference. 10 years ago it was about $650.
As DieselDrax pointed out the payload increase is substantial.
I still like the ride and will continue in the F-350 although I could get by with a F-250 with the 5r we all towing now. Peace of mind and safety factor is worth something.
06-24-2018, 01:27 PM
If you don't waste your payload on the diesel option a 3/4 truck is a lot of truck.
24 Ram 3500 SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
06-24-2018, 01:29 PM
1 ton dually
I originally got my dually when I kept experiencing sway with my 33 foot Sandpiper TT. Two anti-sway bars and a weight distributing hitch did not help. I went through a 2500 Suburban with the 8.1 litre gas engine and a 7.3 litre International diesel Ford Excursion and both has some trouble with the weight and sway of that TT.
Once I got the trailer hitched up to the dually, I had no more sway. That back end was planted! So a big advantage of a dually is sway control in wind.
Then I ditched the TT and went to a fifth wheel and we're in hauling heaven now. I can zoom down the highway with little worry for cross-winds or sway.
I often see these huge 40 foot fifth wheels with six slides going down the road on the back of a 3/4 ton truck -- each wheel riding deep in the wheel well -- and I say to myself, "Sheesh! Would it have killed ya to spend a little more and get a 1 ton?"
But each to his own. If it works for you, I am fine with it!
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
06-24-2018, 01:36 PM
2018 Chevy 2500HD crew cab with 6.0L V8 max payload 3093#.
Catalina 333RETS
Silverado 2500HD
Goldwing 1800GL
06-24-2018, 01:37 PM
I quoted diesels on purpose because they will have the lowest payload. If the choice is to tow with diesel or gas I'll choose diesel every time, a diesel 3/4-ton may not have the necessary payload for a given trailer while a 1-ton SRW of the same truck would have the necessary payload. Point being, the difference between a 3/4-ton and 1-ton truck isn't peanuts as someone stated before.
2013 Shamrock 21SS
06-24-2018, 01:46 PM
Highly doubtful I'll ever get anything I'll need a 1 ton for.
2011 Traverse LT, 3.6L, FWD
06-24-2018, 02:36 PM
I looked at a F350 CC 4X4 DRW to tow 5,600 lb loaded TT GVWR 7000 lb. I thought it would cover any contingency. Then bought a MH instead.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
