Old 10-04-2016, 08:54 PM   #1
Why trailer weight distribution is important
https://youtu.be/4jk9H5AB4lM
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-04-2016, 08:57 PM   #2
KDHfan's Avatar
No link
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-04-2016, 08:57 PM   #3
Fixed
Old 10-04-2016, 09:33 PM   #4
Thank you Paul. Great info.
pibi is offline   Reply With Quote
Old 10-10-2016, 07:12 PM   #5
Nurek's Avatar
Making sure that the trailer height (from ground to bottom of frame) is about 1" lower than the ball height when not connected. Measured between the TT axles on level ground and same with the ball.
IIRC, in my case the height between axles was 23" and the top of the ball was 22" creating a low point in which the WDH was useless and caused my trailer to sway like I was getting hit from nasty crosswinds when there wasn't any. Highway speed. The dealer lifted the WDH ball to 24" and problem solved.
Also that the WDH hook up brackets are equidistant from the coupler.
The dealer that I bought from didn't have it set up properly. 2" differences between the hook up brackets- right side @28" and left side @30".
A good idea is to make sure your front wheel well/fender is riding at the same height after every hook up.
I hope this made sense.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
trailer, weight
