Old 05-10-2016, 06:05 PM   #1
Will I be safely underweight?
I've been reading a lot of the archives and doing some online surfing too. But I'm still not super clear on all the calculations
We are waiting for our 2017 Rockwood 2906ws to arrive at the dealership.
It has a dry weight of 7000# and a payload capacity of 1500#. Tongue weight of 700#.
The tow vehicle is a 2010 ram 2500 crew cab short bed 4wd 5.7 gas with 4:10 gears. It's tow rating is 10,600. I thought I remember payload rated at 2600#
Any advice appreciated. Thanks. Click image for larger version
Name:	ImageUploadedByForest River Forums1462921543.763463.jpg
Cascotter is offline   Reply With Quote
Old 05-10-2016, 06:16 PM   #2
TURBS's Avatar
You'll be fine!
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-10-2016, 06:20 PM   #3
The_Rhino's Avatar
With a payload of 2600 & 4:10 gears you are in great shape!
Our 2011 Ram 2500 CC ST w/5.7 Hemi & 3:73 gears tows our 8,000 lb. (loaded) TT w/loaded tongue of 1100 just fine. Our family of 5 & 1 dog weigh about 700, we have a fiberglass cap, and regularly haul 5 bikes, firewood, etc. under the cap for a payload in the 2500 range. (Our max payload is 3,000 because it's totally stock...)
With the 3:73 gears our 5.7 Hemi towed our GCVW of 15,000 throughout the Smoky Mountains without any issues. With the 4:10 gears you're even better-off.
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2018-25
2017-31; 2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 05-10-2016, 06:50 PM   #4
Prime Member
I tow a 2016 FE BHDS with a 2015 Toyota Tundra. My trailer's dry weight in 7300lbs and my truck's tow capacity is 10,000lbs and it handles it just fine.
Sent from my iPad using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-11-2016, 11:42 AM   #5
OMG you will be just fine.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 05-11-2016, 12:16 PM   #6
Your setup will tow like a charm. No weight police worries for you. Enjoy!
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
ottawapaul is offline   Reply With Quote
Old 05-11-2016, 12:20 PM   #7
I go RV'ing not Camping
jgourlie's Avatar
You are so safe in-fact you should probably get a bigger trailer.
Happy wife is a Happy life
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-11-2016, 12:21 PM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
Originally Posted by Cascotter View Post
I've been reading a lot of the archives and doing some online surfing too. But I'm still not super clear on all the calculations. We are waiting for our 2017 Rockwood 2906ws to arrive at the dealership. It has a dry weight of 7000# and a payload capacity of 1500#. Tongue weight of 700#. The tow vehicle is a 2010 ram 2500 crew cab short bed 4wd 5.7 gas with 4:10 gears. It's tow rating is 10,600. I thought I remember payload rated at 2600#
Good News! You're fine with that combo and should have an enjoyable tow experience.
For the future, if you are like a lot of us, someday you may be wanting to trade that TT for a 5er. When you get there, knowing your true payload will become more important. Simple way to find out. Your truck sticker lists GVWR of 8800#. So go drive it across a CAT scale at a nearby truck stop. Whatever total weight you get, subtract that from 8800# and the remainder is your true payload.
Your payload needs to accommodate the wife and kids, the hitch, and stuff in the truck and of course the 5ers Hitch Weight (some just take the 5er GVWR x 20% and use that for hitch weight). You will see many ultralight 5ers that'll work fine but you may also see many that won't. Beware when the salesman says "You have a 3/4 ton truck and can tow anything on this lot", you can't.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 05-11-2016, 04:07 PM   #9
Truck is fine. Now for that integrated sway control WDH research.....
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-11-2016, 06:40 PM   #10
Get a used Peter built over the road tractor and pull away.
pdqparalegal1 is offline   Reply With Quote
weight
