Old 03-30-2016, 05:29 PM   #21
CWSWine's Avatar
This one be around a while but if you haven't seen it's worth watching. Notice that the truck was DRW.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-30-2016, 05:34 PM   #22
dea49's Avatar
Originally Posted by Pick_PSD View Post
I moved from a 1/2 ton Dodge to a F-350. Hills and wind are SIGNIFICANTLY different now. I had a similar trip last fall on I-20 from Atlanta to Dallas; the wind was horrible but having a heavier truck made all the difference in the world.
What engine do your have in your '06 F350?
dea49 is offline   Reply With Quote
Old 03-30-2016, 05:41 PM   #23
Canadiancrew's Avatar
Originally Posted by Teamfour View Post
You need to have more tongue weight. You are at 10%. See if you can get it to 12.5%.
Agreed. If you have too much weight lifted off the back of the truck it's worse than no WD.
I have a 32 foot trailer which is really heavy in the rear with 2 slides rear of the axle and the f150 sway control has never had to react. It may be all about tweaking your WD.
And with p rated tires pump them to max 44 lbs. my truck came with the factory Goodyears that are like riding on jello bowls rolling the soft side walls.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 03-30-2016, 06:08 PM   #24
Bluepill's Avatar
Manually applying the electric trailer brakes helps to settle the sway a lot. As mentioned already, try different settings of tongue weight and WDH settings, along with trailer tire pressure until you get the most stable ride. It's worth a few hours of your time for more peace of mind, and might just save your butt in an emergency situation.
2008 Itasca Meridian 37H
Old 03-31-2016, 04:36 PM   #25
jlgail4309's Avatar
What was the wind speed ? I try to really watch the wind speed on accweather before planning a trip. We will not travel in winds over 40 .
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 03-31-2016, 05:01 PM   #26
^^This. We aborted a trip just two hours ago due to high winds.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-01-2016, 08:56 AM   #27
6.0 Diesel
It's my first diesel but I have been very impressed. It had a bullet-proof kit done at the shop before I bought it (ARP studs, EGR delete, SCR, etc.) so hopefully it doesn't have any of the issues those 6.0's are known for
2006 Ford F-350
2014 Wildwood 28DBUD
Pick_PSD is offline   Reply With Quote
sway
