Old 08-23-2010, 10:05 PM   #1
Question Wiring Brake Controller into 2011 GM Pickup
Have any of you wired a Tekonsha brake controller in a late model Sierra or Silverado (GMT900 version)? These trucks don't have a plug & play install for aftermarket brake controllers. There is a pigtail harness that has no connector terminal. I haven't gotten the truck yet, so I don't know what the colour codes are.
When I bought my P3 there was a short pigtail for soldering into the factory harness. It has a tag explaining the Ford & Toyota connections, but nothing for a GM vehicle. The 4 wires are black, white, red & blue. I've emailed Tekonsha, but haven't received a reply.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-24-2010, 05:48 AM   #2
Try to find a Chevy/GMC truck forum, someone there may direct you to the codes you need.
bwssr is offline   Reply With Quote
Old 08-24-2010, 06:02 AM   #3
And as a side note, it may come with a controller....
Old 08-24-2010, 09:30 AM   #4
Thumbs down
I'm on gm-trucks.com, but I'm hesitate to ask there as I'm not entirely confident w/ some of the answers for questions posted.
Old 08-24-2010, 09:38 AM   #5
Hi:
You may have a pigtail that plugs into the port under the dash. It should have been included with your truck. If you lost it, you can order one from the same supplier that you bought the controller from. It is the same as the GM origanal. It just plugs right into the receptacle under the dash and the back of the controller - No soldering or running power lines or anything if you are already "Tow Ready". This can be verified by looking at your bumper and finding a 7 pin RV/trailer receptacle. If it's there, you are prewired for the brake controller.
turbopuppy is offline   Reply With Quote
Old 08-24-2010, 09:49 AM   #6
Unfortunately GM no longer provides a connection to plug a brake controller into. As per their brochures:
includes a 7-wire harness with independently fused trailering circuits mated to a 7-way sealed connector and 4 blunt-cut wires in the instrument panel for an aftermarket trailer brake controller
I just fired off an email enquiry to GM's Customer Assistance Dep't. I'll post when I hear back from them.
Old 08-24-2010, 10:57 AM   #7
milzat's Avatar
Will this help.
milzat is offline   Reply With Quote
Old 08-24-2010, 01:21 PM   #8
doctort44's Avatar
eTrailer also has a set of instructions with pics. When we bought our rig I got the Prodigy controller and took a printout of those instructions (with photos) to the tech at the dealer, because he didn't know how to install it on my truck. He had no problem after he read through it.
Terry and Joan and our empty nest
2008 Silverado Crew Cab 5.3liter 3.73
"The Cottage" (2010 Surveyor Sport 189)
doctort44 is offline   Reply With Quote
Old 08-24-2010, 01:55 PM   #9
Thumbs up
I got this link thru gm-trucks.com:
http://www.eworldz.com/truck/gmt900.pdf
Old 02-16-2011, 09:34 PM   #10
Cool
I finally got around to installing the controller today. No issues to speak of. The only "glitch" (insignificant) was that for whatever reason, the wire under the master cylinder & the 40 amp fuse had been connected/installed @ the factory.
brake control, brakes
