02-20-2014, 10:38 AM
Would this be a good truck to tow with?
I found a 2003 F150 extended cab 4wd with a 6.0 turbo diesel for $15,000. It has 73,000 miles and carfax is good. I am wanting to pull something like the xlr 27 hfs. I would appreciate your comments, thanks.
02-20-2014, 10:56 AM
PPST OGCDG
A 2003 F150 extended cab 4wd with a 6.0 turbo diesel???
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
02-20-2014, 11:18 AM
Has to be F250 or F350. I have heard bad things about 6.0 ford diesels. Check the Ford or Powerstroke forums for more info.
2012 F350 Lariat CC SRW 6.7L Powerstroke
02-20-2014, 11:30 AM
02 and 03 6.0’s are the years to avoid.
International DID NOT clean all the sand out of the blocks which clogged the EGR cooler.
Our 05 6.0 was flawless (the hydro boost (brakes) failed early), exceptional puller.
I would not buy the 03, anything newer should be fine, if you DO NOT put a chip in it.
ab&jb
EDIT: If the 03 has a add on coolant filter, head bolts replaced with studs and an upgraded or deleted EGR then I would take a serious look at it!
2012 Georgetown 360
SHE wanted "a new motorhome"
02-20-2014, 11:37 AM
I agree about the 6.0 and that price seems a little high IMHO. I bought a 2003 F250 CrewCab with the real diesel engine 7.3L about 2 years ago for $10000. It had higher mileage 189,000 but hasn't skipped a beat and I have put about 12,000 miles on it.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
02-20-2014, 11:42 AM
Sorry, I meant to say F250. I have an f150 now.
02-20-2014, 12:10 PM
offer them 12k and you got a steal after you fix the issues with the EGR, best low budget truck/eng combo out their, cant beat it after you bullet proof the engine
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
02-20-2014, 12:16 PM
Camper Less Camping
I'd try to buy it for $12...then as others stated, spend an additional $3-5K on bulletproofing it and you'll have a great tow vehicle.
2013 Sabre 32RCTS-6 (sold)
02-20-2014, 01:22 PM
PPST OGCDG
In my 04 noticed a small amount of oil in the Degas bottle. Did some checking and found that the Oil cooler had just started leaking caused by the EGR Cooler plugged up. Changed the Oil Cooler (OEM) and replaced the EGR Cooler with a Bullet Proof EGR Cooler.
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 and 6.4
Frank- VA {:-{)
02-20-2014, 01:30 PM
after working 18 years as a Ford dealer tech, I can attest to what everyone else is saying. If you bullet proof it first, you will be ok. Take note as to what I'm towing with though.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
02-20-2014, 01:32 PM
or step back to the years of the 7.3. Not quite as much power, but reliability WAY better, and any needed repairs lots cheaper as being easier to work on.
02-20-2014, 02:15 PM
ab&jb
Ford did not make the 6.0 in 2002
Brother Les
02-20-2014, 02:21 PM
False, it is the
silica coolant that is the problem .
Refill it with a silicate free Cat EC-1 rated ELC coolant and the 6.0 was not offered in 2002
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
02-20-2014, 03:08 PM
A coolant filter is a good add on for any diesel that doesn't have one. Cheap too!
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
02-20-2014, 05:22 PM
I own two vehicles with the 6.0. Both are great for towing...and not bad on mileage either. The 6.0 is not a bad engine if you know what you're getting into....Get a scan gauge from autozone to diagnose the truck during your test drive. Check the difference on the Oil Temp and coolant temp. after the truck is fully warmed up (at least 185 or so). Go for a long drive on the highway and keep it at 65mph. After 15-20 minutes, if the difference between the oil temp and coolant temp is less than 15 degrees, you've got a potential keeper. If it is more than that, you're going to need to replace the oil cooler. The bigger the difference, the more pressing the need to replace it. Check to make sure the FICM never drops below 47 Volts (using the scan gauge). Keep only OEM filters on it and do maintenance on schedule.
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
02-20-2014, 08:05 PM
PPST OGCDG
2X the above Quote.
I have the Scan gauge and it works great. If you buy it through Bullet Proof it already preprogram for the 6.0.
ScanGauge II Digital Data Monitor
Frank- VA {:-{)
02-22-2014, 08:42 PM
Incheon, S. Korea
Originally Posted by jevanb
False, it is the
This is the issue that I have seen everywhere too.
I'd wouldn't even look at it for more than $10K and then I'd take it to a shop and put studs, gaskets, EGR delete.... Around $5K in total. Then it'll be bullet proof.
Just because it's good now doesn't mean it isn't going to fail.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
02-22-2014, 09:07 PM
Or you can find a Duramax or a Cumalong and just drive it.
02-23-2014, 05:00 AM
Incheon, S. Korea
True. True. LOL
02-23-2014, 06:57 AM
Hmmm...not a good endorsement for Ford.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
