Old 02-20-2014, 09:38 AM   #1
Would this be a good truck to tow with?
I found a 2003 F150 extended cab 4wd with a 6.0 turbo diesel for $15,000. It has 73,000 miles and carfax is good. I am wanting to pull something like the xlr 27 hfs. I would appreciate your comments, thanks.
comfun1 is offline   Reply With Quote
Old 02-20-2014, 09:56 AM   #2
PPST OGCDG
Frank-VA's Avatar
A 2003 F150 extended cab 4wd with a 6.0 turbo diesel???
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 02-20-2014, 10:18 AM   #3
Has to be F250 or F350. I have heard bad things about 6.0 ford diesels. Check the Ford or Powerstroke forums for more info.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 02-20-2014, 10:30 AM   #4
abjb's Avatar
02 and 03 6.0ís are the years to avoid.
International DID NOT clean all the sand out of the blocks which clogged the EGR cooler.
Our 05 6.0 was flawless (the hydro boost (brakes) failed early), exceptional puller.
I would not buy the 03, anything newer should be fine, if you DO NOT put a chip in it.
ab&jb
EDIT: If the 03 has a add on coolant filter, head bolts replaced with studs and an upgraded or deleted EGR then I would take a serious look at it!
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-20-2014, 10:37 AM   #5
I agree about the 6.0 and that price seems a little high IMHO. I bought a 2003 F250 CrewCab with the real diesel engine 7.3L about 2 years ago for $10000. It had higher mileage 189,000 but hasn't skipped a beat and I have put about 12,000 miles on it.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 02-20-2014, 10:42 AM   #6
Sorry, I meant to say F250. I have an f150 now.
Old 02-20-2014, 11:10 AM   #7
jevanb's Avatar
offer them 12k and you got a steal after you fix the issues with the EGR, best low budget truck/eng combo out their, cant beat it after you bullet proof the engine
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-20-2014, 11:16 AM   #8
Camper Less Camping
Cajun Po-Boy's Avatar
I'd try to buy it for $12...then as others stated, spend an additional $3-5K on bulletproofing it and you'll have a great tow vehicle.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-20-2014, 12:22 PM   #9
PPST OGCDG
Frank-VA's Avatar
In my 04 noticed a small amount of oil in the Degas bottle. Did some checking and found that the Oil cooler had just started leaking caused by the EGR Cooler plugged up. Changed the Oil Cooler (OEM) and replaced the EGR Cooler with a Bullet Proof EGR Cooler.
BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 and 6.4
Frank- VA {:-{)
Old 02-20-2014, 12:30 PM   #10
davel1971's Avatar
after working 18 years as a Ford dealer tech, I can attest to what everyone else is saying. If you bullet proof it first, you will be ok. Take note as to what I'm towing with though.
David & Lynn
truck
