Old 08-15-2016, 08:27 AM   #11
Originally Posted by 05CrewDually View Post
I don't know why you're quoting me. I'm not saying anyone's right or wrong. I gave the best logical answer to there problem, which was further explained in their post #4.
All the other variables in trailer plug wiring info is TMI and I can see now how they can get confused.
Yellow is for reverse lights. It's the center pin on the plug. I'm not sure what your confusion is. ,,,,,that's why
Maybe you should have read my entire post instead of assuming because there are THREE DIFFERENT 7 wire CONFIGURATIONS and YELLOW is NOT ALWAYS the REVERSE LIGHT WIRE
ShermanD is offline   Reply With Quote
Old 08-15-2016, 09:42 AM   #12
2007 WildCat 32QBBS
05CrewDually's Avatar
I know that but it doesn't pertain to the OP. Go back and read post #4.
05CrewDually is offline   Reply With Quote
Old 08-15-2016, 09:49 AM   #13
Witch Doctor's Avatar
Yellow is for reverse lights. It's the center pin on the plug. I'm not sure what your confusion is. If you don't have or want any backup lights then don't use it.
You are correct according to my wires the yellow to the center will work both your left signal and reverse tail lights if you hook it to the center pole. Just leave it capped off and don't hook anything to the center pole, it will back feed.... PS: do not use the standard TT wire diagram. OP I can copy how I hooked mine up if needed. you only use 6 wires.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-16-2016, 10:19 AM   #14
Originally Posted by rockfordroo View Post
Curt:
Herks drawing shows the wiring colors in the umbilical cord you plug into your tow vehicle.
If you open up the junction box that the umbilical cord is routed to, I believe you will find that the colors will change to the ones in your pic.
In other words, the Tow Vehicle/Plug colors are not the same as the actual wiring in your TT from the junction box to all the lights, etc.
I ran a standard 4-pin connector from my rear bumper to the junction box to power the LED's on my bike rack. The TT lights' wire colors were not the same as the umbilical cords wire colors. I wrote them down, but they're in the TT in storage at the moment, so I can't tell what they are.
I've attached a pic of the 4-pin wires, not that it helps much.
Agreed. ...there seems to be no consistency from the TV plug to the junction box. These trailer folks seem to have complete disregard for wiring codes and colors. I've added some extra signal and marker lights to my TT and have done the same...started my own code as notes in my phone!
Filterman is offline   Reply With Quote
Old 08-16-2016, 07:34 PM   #15
The Y wire in my CC-29RE was capped inside the front storage area.....I extended this wire with Y wire to the back of our 5er.....Installed a backup beeper unit and also a LED backup light on drivers side of 5er......J
Jim in Halifax is offline   Reply With Quote
Old 08-17-2016, 10:28 PM   #16
Curt and Michele's Avatar
Originally Posted by Bama Rambler View Post
If the center pin is connected to something and you don't have reverse lights or a backup camera, then we can't tell you what it may be hooked to. And there is a possibility that it isn't hooked to anything, but got temporarily shorted and that's what caused the insulation to melt.
You should be able to open up the junction box under the RV and see if the yellow wire is actually hooked to anything.
And that's were my problem lies, I pulled the cord out of the junction box and in the junction box is nothing but brown wires, except for hot, ground and electric brakes.
Maybe I should not have put this under Tow Vehicle but figured if I could positively figured out what the yellow wire coming off the TV may go to I could trace it down some how.
Once again Thanks everyone.
F250 6.7 Diesel 4X4 Crew Cab
2015 Coachmen Chaparral 5th Wheel 336TSIK
Curt and Michele is offline   Reply With Quote
Old 08-18-2016, 02:26 AM   #17
I just replaced my cord, the yellow wire from your TV is for the center post or revise light, on your trailer the yellow wire is capped off in the box the cord ties into, just did this yesterday.
Old 08-18-2016, 02:30 AM   #18
White and black are power from your Trailer
Red and brown turn signals, blue is brake ,green is running lights. That is the way mine is wired.
Old 08-18-2016, 06:25 AM   #19
Head Rambler
I understand your confusion. Once you got to the junction box all bets are off because all the wiring to the lights are the same color wires. I think mine is like that too. However you said that everything is working except that you can't figure out what the yellow wire on the umbilical cord is supposed to do. that's why everyone is concentrating on the yellow wire.
Can you take a picture of the wires in the junction box? I know it'll be a challenge, but I think it'll be worth it.
Here's another thought. Is the end of the yellow wire tinned (filled with solder)? If it is then that could be why the insulation is melted. They could have done it when they tinned it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-18-2016, 06:54 AM   #20
Herk7769's Avatar
If all of the wires are currently disconnected, and you have a volt meter, separate the pigtail wires, strip and tape them individually and plug the pigtail into the truck.
Using a volt meter on VDC (or DCV in this case), monitor all the trailer side wires for the one with 12 volts. That wire goes to the trailer battery and needs to go to the red wire coming from the pigtail. Mark and tape a tag to it.
Next, meter the voltage on the pigtail yellow wire. Turn on the left turn signal and if the yellow end goes to the truck's left turn signal, the voltage should swing between zero and 12-13 volts or so (you may need the truck running).
If so, using a short 5 amp FUSED jumper wire from the yellow wire, test each brown end in the junction box to see what turns on. If you find the ground wire by mistake the 5 amp will open before any damage is done to the truck. Label the wire with a small tape tag.
Repeat with the right turn signal.
Turn on parking lights and identify the wires going to the marker lights.
NOTE: depending on how your side and top marker lights are wired, 5 amps may not be enough to handle them all if there is only one wire to all of them. The some incandescent bulbs can draw up to 1.2 amps each (LEDs draw MUCH less and 5 amps will always work regardless of how the markers are wired). If the markers draw more than 5 amps, identify all of the other wires first before increasing the fuse to 7.5 amps and then to 10.
The brakes and ground wires will always be "cold" until someone taps the brakes in the truck. Then the brake wire from the truck will show some voltage. The easiest way to identify the brake wire from the trailer side by pulling the breakaway momentarily (long enough to take a reading) as the trailer battery will be sending power on that wire when the break away is pulled. Be quick about it as the brakes will be pulling full power from your battery and may overheat if left on too long (no more than 5 minutes as you will also be running your trailer battery down).
Once you have identified all the correct wires, write down the color code/tag numbers for your particular camper.
HAM CALLSIGN - KC3FFW
