Old 10-11-2015, 07:26 PM   #1
Cyber Phrenologist
Radio's Avatar
Yellowed and clouded headlights?
Radio's been shopping again...
And found a solution for fogged and yellowed headlight covers that actually works and only costs $8.00.
3M Headlight Renewal. It seems to be a polishing or buffing compound for the plastic material headlight covers are made off. Looks just like certain kinds of metal polish. In addition to the compound you will need an old towel. Squeeze about a half dollar size spot onto the towel and apply it all over the headlight cover. Then get the clean end of the towel and buff like crazy for a few minutes. I recommend using latex gloves.
Done. Just about like waxing any other part of the vehicle. Will not hurt paint.
Other headlight solutions cost $40 and you need a drill to spin the buffing wheel that comes with it. Nope. All you need is $8 and an old towel. One bottle will do a bunch of cars. Also found it will brighten up any other plastic lens and some of the emblems and badges on the vehicle.
Got mine at Autozone.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 10-11-2015, 08:07 PM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
The problem is if you stop there in a few months or less they will be clouded over again. The key is to coat them with a clear coat after your done polishing. I haven't found yet what or if there is a specific clear coat to use.
05CrewDually is offline   Reply With Quote
Old 10-11-2015, 08:15 PM   #3
Left Coast
There's also a product sold on Amazon called Wipe New, $10.00. Comes with a piece of 4000 grit sand paper to wet sand the lens, than a apply cloth and a solution you just wipe on. The key is the wet sanding. Some this stuff at HD the other day for $20.00!
Old 10-11-2015, 08:42 PM   #4
Tfort's Avatar
Regular clear coat will not last long either. The key is to wet sand the headlights and then coat them with a uv protectant clear coat. We use this stuff at work and it lasts if prepared and applied correctly. They say to use a uv light to cure it but we also put them in the sun for a couple hours to cure as well. You can get it at glassweld.com Click image for larger version
Name:	ImageUploadedByForest River Forums1444614104.544464.jpg
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 10-11-2015, 08:43 PM   #5
I use Colgate toothpaste, on a damp rag. Lasts about 6 months.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 10-11-2015, 08:50 PM   #6
muddyrode's Avatar
We use bug spray tried off just a couple weeks ago on friends car and it worked not sure how long it will last
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 10-11-2015, 09:03 PM   #7
Cyber Phrenologist
Radio's Avatar
I have a friend who treats his with Deep Woods Off. About once a month, he says!
So I don't know how long the shine will last. I do know this stuff is cheap and easy. And there's enough stuff in the bottle to last for years.
Before I found this stuff I gave some thought to using DuPont #7 Buffing Compound. I once used that restoring a MGB roadster, made all the colored plastic lenses look new.
We did my wife's Freestar van and my daughters Honda. My '07 F-150 with 136,000 miles, has never needed it. Go figure.
KU4OJ
Old 10-11-2015, 09:05 PM   #8
Yep, we used Deep Woods Off, which we had on hand and it worked fabulously.
merrykalia is offline   Reply With Quote
Old 10-12-2015, 12:30 PM   #9
I just went on ebay and bought new headlight assemblies. Want worry with the dingy stuuf ever again.
lazyjj is offline   Reply With Quote
Old 10-12-2015, 03:17 PM   #10
Luckybreak
Luckybreak's Avatar
x2
2013 Chevy 2500HD
2001 Flagstaff 26RKS
Luckybreak is offline   Reply With Quote
light
