Old 10-13-2015, 05:50 AM   #11
davel1971's Avatar
Originally Posted by canbyfam99 View Post
Excuse my "newness", I assume you are talking about on the Silverado? We actually don't have a sticker on our door but it is by the hitch under the truck. Listing 12,000 with a 1,200 payload.
tow ratings are NEVER on the truck. What you are seeing is the rating of the hitch itself, not the truck. You are likely a few thousand pounds less than what you think, making this trailer not possible. You may have the 11,200 rating, but that is only with 3.73 gears. No crew cab 4x4 configuration has a 12,000 lb rating.
David & Lynn
Old 10-13-2015, 06:39 AM   #12
I am guessing everyone is right... And we do have the 3.73... I apologize for leaving that out. Like I had said earlier... I can not find another sticker on the truck but will keep looking. We are very new to this and this will be our first TT.
All
Greatly appreciate all the advice!!!
canbyfam99 is offline   Reply With Quote
Old 10-13-2015, 06:43 AM   #13
TURBS's Avatar
Look at the yellow "tire loading" sticker on the driver's door jamb.
You'll run out of payload waaaaaay before you run out of max tow.
Old 10-13-2015, 06:46 AM   #14
TURBS's Avatar
This
Old 10-13-2015, 07:11 AM   #15
Originally Posted by TURBS View Post
This
Okay thanks... Got it!!! Click image for larger version
Name:	ImageUploadedByForest River Forums1444738252.537030.jpg
So it looks like 1646lbs in the TV
Old 10-13-2015, 07:25 AM   #16
Okay so to clarify we have a 2014 Silverado 5.3L V8. (3.73 rear axle)
With max trailering package
We will assume the 11,200 tow rating and it appears from the sticker we have a TV payload of 1646lbs.
With max passenger and some stuff we would be looking at 800lbs in the TV.
Thanks everyone for your patience!!!
Old 10-13-2015, 07:45 AM   #17
Lastly, my husband just read that our GVWR is 7200lbs and with everything else he has equipped on his vehicle we will be able to handle this...
With everyone's help we were able to get further information so thank you all😊
Old 10-13-2015, 07:58 AM   #18
Before you buy airbags try the WDH, I use the Equalizer and it works fine. I installed airbags on my Silverado 1500 to tow a 2702ss Rockwood (about 6000 lbs). I found them pretty much usless after the Equalizer install. If you decide you need them they will affect how the WDH is setup.
Brewhedd is offline   Reply With Quote
Old 10-13-2015, 08:17 AM   #19
That is helpful, thank you! We had definitely planned on the WDH and Chevy actually recommends it too!
Old 10-13-2015, 08:20 AM   #20
TURBS's Avatar
Remember the wdh "weight" is also considered "cargo"
If air bags are added they to are considered "cargo" as well.
Wdh and air bag system must be deducted from ccc number.
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
newbie, towing
