Old 06-16-2016, 07:08 PM   #21
Iwannacamp's Avatar
Originally Posted by Tireman9 View Post
The issue is not sidewall flexibility. Forces that allow tires to turn corners are much more complex than simple bending of a tire sidewall. The primary issue is the Cornering Coefficient that is developed by the tire as the path traveled differs from the direction of rotation.
You can find some background info HERE.
The actual issue you might want to think about is not simple side bending but twisting stiffness. Cornering forces are transmitted from the wheel through the tire sidewall by twisting, then to the belt package and finally the tread rubber. Each component has an inherent stiffness that tries to resist the turning forces.
The cornering force generates a shear force between the belts and the body. That is a relatively weak link. If the repeated forces exceed the strength of the rubber to resist tearing than you have a good chance of experiencing a belt/tread/body separation. Once this separation grows in size over many hundreds or even thousands of miles these components come apart. When this happens the tearing may be limited to just the layer of rubber between the tread and top belt or between the two belts or between the bottom belt and the body. This tearing can easily move to the rubber between the body cord and result in a breach of the air chamber. This leads to a rapid loss of air pressure which many incorrectly ascribe as the reason for the failure and not the result of the failure. Hence the "I had a Blowout" complaint. Yes the driver was surprised when he heard the loss of air but he often jumps to the wrong conclusion.
Increasing tire inflation, as I have often suggested, can alter the cornering forces and the sidewall stiffness and the 'slip angle". Finite Element modeling has identified the level of shear forces between various components and found that multi axle trailers can experience 24% greater shear forces that tires on a motorized vehicle.
This post offers additional information on Interply Shear.
You have it in your power to lower this shear force by:
Increasing tire inflation and by Increasing the Reserve load with higher Load Index with the associated increase in inflation and by Increasing the tire size that will also increase potential max load capacity and result in increased Reserve load.
RE LT tires vs ST tires. IMO I think you are more likely to find the latest technology and best durability in tires made by the "Big Three" or as applied OE to current model Pick-ups.
If I ever argue or question your tire knowledge...you have permission to smack me.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-16-2016, 11:17 PM   #22
Originally Posted by checkmate99 View Post
Buyer Beware! Did I get it right?!! Watch Judge Judy every day!!
We have a winner! lol.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 06-22-2016, 10:47 AM   #23
Originally Posted by Davidg View Post
There is a very suitable Greek phrase that comes to mind when I think of buying a used camper...especially from cw..."Caveat Emptor"
Someone will be along shortly to interpret...
Were it me, I would drag that camper back to cw and ask the manager how dry rot could ever pass an inspection. If nothing else, I would get a measure of satisfaction. What you describe is a fraud on the customer. Were the fellow to have a blowout and someone was hurt or worse as a direct result of bad tires, the old fellows insurance co's lawyers would be very interested.
But another great Camping World story.
King_arthur1953 is offline   Reply With Quote
Old 06-22-2016, 12:46 PM   #24
Commercial Member
Sorry not Greek but Latin
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is online now   Reply With Quote
tire
