Old 05-29-2016, 06:53 PM   #11
Kenny kustom's Avatar
Put them in.
Use manual fill. There's really no need to be able to change pressure on the road.
Like driving along and be like ... " I think it needs a couple more lbs".
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-29-2016, 06:56 PM   #12
Originally Posted by BandJCarm View Post
Yes, thanks. I've heard that from others too.
(I need a loan.......and haven't even camped yet except stopover on way home).....
Just curious but what kind of tires do you have on the camper? My Cedar Creek sometimes gets a little bouncy.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 05-29-2016, 07:17 PM   #13
BandJCarm's Avatar
Westlake 14ply G rated 16"......
I can't make myself spend the money to replace new tires with G614's.......but I may regret that.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 05-29-2016, 07:20 PM   #14
We have had Firestone Ride-Rite air bags on our last three half-ton pickups.
They give excellent stability when towing and normal ride when the bags are at 10 lbs. The bags don't increase load capacity, but the do help the rear springs. In eleven years use, we have found no disadvantages.
PenJoe is offline   Reply With Quote
Old 05-29-2016, 07:57 PM   #15
W5CI's Avatar
Bill did you ever go weigh your rig at a CAT scale, that will tell you your axel weights, with a Dully and a 5er it wont ride like a suv or a 1/2 ton pu
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 05-29-2016, 08:10 PM   #16
Usually Confused Member
emm-dee's Avatar
I use the wireless controlled AirLift compressor so I can adjust the pressure when unhooking or hooking up at the campsite. Can't usually find air there for manual fill. Also have the manual fill shrader fitting in the rear bumper. I occasionally hear the compressor turn on or the air release activate due to outside air temperature changes. The AirLift unit will not allow the bags to go below the recommended 5 psi so if you hear it running a lot you know there's a leak.
Biggest advantage I've seen with having the bags is major improvement in stability. They also prevent the wheel hopping that happens when you accelerate a little to quick on wet roads.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 05-29-2016, 08:13 PM   #17
Try Bilstein shocks to control bounce.
I use the AirLift ultimate 5000 air bags and Bilstein shocks on my F250.
We're pulling a Rockwood Windjamer 3029 and use an Equalizer 4 way 1200/12,000 hitch.
Rig is rock solid in all towing enviornments.
GaryHowe is offline   Reply With Quote
Old 05-29-2016, 08:55 PM   #18
I have bags on the Chevy traverse made a good difference I only paid 139 plus 100 for install so worth it
2016 mini lite 2306
2012 Chevy traverse
Locchamp is offline   Reply With Quote
Old 05-29-2016, 09:16 PM   #19
Tom48's Avatar
Originally Posted by youroo View Post
With recommended "No Load PSI" the TV will perform normal! Youroo!!
We are in a F250 6.0 liter D. With the big Lance camper we ran about 90 psi With 8000 lb bumper pull and 1000 toy in the bed we run 50. Empty I leave 10 in them
The camper could bounce a little, the trailer, w load,. Never bounces.
Tom48 is offline   Reply With Quote
Old 05-29-2016, 09:54 PM   #20
I go RV'ing not Camping
jgourlie's Avatar
I say go for it there are no disadvantages
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
air bags
