Old 05-29-2016, 10:18 PM   #21
Air Bags
Yes I would install them in your truck. I also have a 3500 Dually GMC and I installed them in the truck. With a pin weight of our toy hauler at around 3300 pounds I found they really helped.
3freedom is offline   Reply With Quote
Old 05-29-2016, 10:19 PM   #22
mlatter's Avatar
I am in the "shock absorber" camp as well. The biggest difference ever on my rig was the installation of Rancho RS9000XL shocks, set at the firmest position. Bridge joints, and railroad tracks are a joke now compared to the original shocks - no bouncing around at all. Goes over them like a car. Air bags leveled the truck, but didn't change the ride much while towing. I think quality shocks are your best bang for the buck at this point.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 05-30-2016, 12:14 PM   #23
tstillman's Avatar
Originally Posted by BandJCarm View Post
Thanks!
So, do you notice any adverse condition while driving the truck around town, or on highway, without the camper????
I recommend adding the bags. I drive an 2010 F350 SRW and experienced a pinion shutter that was totally eliminated with the addition of bags. All this without any ill side effects.
Good luck, of I were you I'd add them ASAP, oh yeah I did.
tstillman is offline   Reply With Quote
Old 05-31-2016, 11:11 AM   #24
BandJCarm's Avatar
The end....
They're being installed in the morning
Thanks guys
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-31-2016, 08:39 PM   #25
Usually Confused Member
emm-dee's Avatar
Pinion shudder. OK, thanks. I've been looking for that definition for a long time and glad someone mentioned a logical name for the problem. I googled it to verify and found some good info about it.
The 1500 series trucks of today, especially the Gen 4 Ram models, are more like a really big SUV. They are purposed for just everyday runaround and hauling light loads. They are also very capable TT pullers if one knows how to select the correct trailer and mods/additions.
The biggest problem with the Ram 1500 is that it is way overpowered for everyday use (not hauling). If you are sitting still and slam the throttle to the floor you will be introduced to some aggressive "wheel hopping". It's even worse on wet pavement. Sometimes it feels like the rear wheels are actually jumping off the pavement. But they are getting light enough during the "hop" that you will hear multiple quick tire squeals.
When I installed the airbags I noticed a significant reduction in hopping when set to 5 psi. At 12 psi the problem completely disappears. Obviously, the airbags have done a good job of stabilizing the rear end. Seeing the operation of the bags agrees with some technical articles I read regarding pinion shudder.
Add the airbags, E-load tires and a Class V hitch (attach points on the Class V extend further forward than a Class IV) and now you have a pretty good tow vehicle.
I'm not sure about the 2500/3500 trucks (or even other brands) but I think they have at least some of the same problem. I also have them on my 2500 Ram CTD and they really smooth things out.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 06-06-2016, 07:05 AM   #26
BandJCarm's Avatar
First minor test in an hour. Have an old 84 chevy truck hooked up on a car hauler trailer at the farm, heading 2 hours home shortly. I will mess with the remote to see what happens.
Big test next Tuesday....first camping trip....800 mile trip.
FROG AR-0019-242
Old 06-06-2016, 09:11 AM   #27
I put air bags, Firestone RideRite on my Silverado 2500 and I never noticed a difference. I have a Silverado 3500 now. But it's your money and it all comes down to what you like.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 06-06-2016, 09:14 AM   #28
dcheatwood's Avatar
I have airlift 5000 bags on my half ton. Much better ride with 45-55 psi. Down to 5 psi when not towing. Normal ride then.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 06-10-2016, 09:10 AM   #29
BandJCarm's Avatar
OK, the big first trip starts Tuesday morning. I put 10 psi in the air bags around town and it's ok, fine.
I towed a car hauler with an old pickup truck on it (probably 4K pounds?) and played with the air bag settings. It did seem to matter if/when I aired up on the fly to about 35-45 psi.
One question........and I read this somewhere (?).........should I inflate the air bags to about 50 or so (???) BEFORE I hook up trailer? I can adjust via bluetooth on the fly anyway, and probably will.....so not sure why this would matter. But someone said to, I think.
FROG AR-0019-242
Old 06-10-2016, 01:33 PM   #30
tstillman's Avatar
On my rig I played with it on a flat level surface to get the ride height level front to back and side to side with the load on board. When disconnected I noticed the rear bumper raise nearly 2.5 inches. I then measured the air pressure on each side. It measured at 48 Left and 50 right.
That is now my starting point to fill the bags before hooking up the 5th wheel. (Note with a load on I would assume the pressure in the airbags would be higher.) After trip is over I drop pressure to 5lbs in each which is the recommendation from the manufacturer.
Honestly I hardly notice anything is even back there and have not experienced any evidence of a rough ride in route to our destination.
Good questions. I'm sure you're going to enjoy this upgrade and happy camping.
Tom Stillman
Vancouver, WA
2012 Forest River Wildcat Sterling Edition
2010 Ford F350 Super cab (With all the junk taken off) With H&S tuner and set of bags on the back.
air bags
