Old 10-28-2014, 12:21 PM   #31
thebrakeman's Avatar
800 lbs would be perfect. Unfortunately, if you want to go with the highly-recommended Equal-I-zer WDH kit, 800 is not available. You'll need to choose between 600 and 1000. I really don't think you are going to be near 700lbs TW, and probably much closer to 600. But I would rather have too much WD than be right on the edge. Being at the limit tends to make for a bouncy ride, ("porpoising"). The higher spring rates will make the coupler-joint-connection more rigid, but should not be excessive. Again, 800 would be perfect, but 1000 should still be OK.
My camper is loaded to about 5000 lbs, and the 1000lb Equalizer is not harsh for me.
thebrakeman is offline   Reply With Quote
Old 10-28-2014, 01:29 PM   #32
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by John and Lori View Post
My tires are goodyear wrangler 275 55 20s
Look on the sidewall for max inflation pressure and set it there for towing. My Tundra came with passenger (P) tires. Inflation specs on door jamb said 38 psi. I pumped 'em up to 44 psi. while towing. Made a big difference. I now have LT tires and carry 60 psi. while towing.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-28-2014, 01:52 PM   #33
Arefbee's Avatar
WDH is the way to go. It will help and is less likely to fail than airbags (IMHO).
LT tires too. It will be a harder ride but work it for control.
For more info on WDH Trailer Hitches & Vehicle Accessories (800)298-8924
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 10-28-2014, 02:28 PM   #34
Check out the Fastway E2 WDH system. It is a basic WDH plus sway control, similar (though not as good) as the Equal-I-zer. They have an 800 lb size that would be perfect for your needs. Tweetys and RV Wholesalers both sell it. I have used both for various things in the past, and they have treated me well.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 10-28-2014, 03:20 PM   #35
X2. With a rig that small- and you've already said you don't have a sway issue- the E2 would be perfect. RVWholesalers has had the best price on hitches in my experience.
Old 10-29-2014, 09:13 PM   #36
jb3-7-77's Avatar
Folks,
I just picked up by MicroLite 21fbrs today and towed it home. I drive a 2007 Tundra 4wd with tow package so the 3800 lb trailer is not an issue in that respect. I had 18 wheelers pass me on interstate and absolutely NO sway whatsoever so I am good there, My question for you tow experts is what the best way to stiffen the rear springs, the tongue weight is around 200 to 400 lbs depending on who you believe but I have yet to measure it. The Tundra handles it well but seems a little soft and I don't really want to go with a redistributing hitch but would prefer a modification of the rear suspension if possible, any suggestions would be great and I thank you in advance.
JW
I read on further where you said you weren't "dead set" against a WDH, however I am curious if there was any particular reason why you were against them?
jb3-7-77 is offline   Reply With Quote
Old 10-29-2014, 09:43 PM   #37
When you go the wdh route, dealer installed mine and i took for granted they knew what they were doing, wrong. Look it over, they are simple, Any questions call manufacture. I have a curt and they (Curt) very helpful on my questions. Dealer did not install spacers on upper part of hitch onto bracket, after 4 hrs towing i looked at it and was like huh, why is the ball rotated up so far. .hehe. check and re check.
TV- 2014 Silverado 1500 5.3 CC SB 4x4 rated
TT- 2015 Puma 19rl
Curt 51120 brake control
Curt Round bar wdh
Curt sway control
Firestone bags
lazypuma is offline   Reply With Quote
Old 10-29-2014, 10:07 PM   #38
camper1999's Avatar
WDH, Timbrens, LT tires. That would cover it.
2011 GMC 2500HD Diesel
Old 10-30-2014, 07:31 AM   #39
I replaced my rear shocks with Rancho RS9000XL adjustable shocks. This helped greatly to stop any porpoising. Rides better unloaded, too.
Old 10-30-2014, 04:38 PM   #40
I thought they were not needed for a set up so small, I worried about the possible loss of rear traction and I guess I don't like new things LOL
2015 Microlite 21FBRS
2007 Tundra Limited 5.7 4wd double cab.
John and Lori is offline   Reply With Quote
towing
