Old 04-09-2015, 08:11 PM   #11
My dealer gave me a 4000 lb Equal-i-zer with my Roo 19. When I put the Roo 19 info into Equai-i-zer's calculator (4770 GVWR, 500 lb tongue) it says it should be a 6000 lb. When I add 100 lbs for my bikes on the back, it says 6000 lb, but says, "However, you appear to be close to exceeding the maximum weight rating of the hitch. You may want to consider a heavier hitch, especially if the amount of cargo you are carrying increases."
All that being said, though, I haven't had any issues with my 4000 lb hitch. It seems just fine. And I can really tell the difference with the bars installed vs just the ball.
2011 Traverse LT, 3.6L, FWD
Old 04-10-2015, 10:49 AM   #12
Thanks!
Thanks for the tips everyone and I've decided to go with...
The Andersen WDH (thanks Hbillsmith for opening my eyes, I'd never even heard of it until now). My decision to basically do a 180 was based on:
Andersen Hitch (AWDH) is light...much lighter and easier to hook up than the Equalizer (EWDH). So, my wife could even do it. I didn't realize the EWDH is so heavy.
AWDH is quieter. I also didn't know how noisy the EWDH was until now.
AWDH is easy to setup and adjust for me. I can "borrow" a torque wrench from the auto store and set it up in less than 2 hours (most say an hour but I'm slow at these types of things)
AWDH is cheaper...not by much on the hitch itself but installing it myself will save me $200 total.
But most importantly, I did a ton of research last night and the only complaints I could find at all on the AWDH from actual owners were that it doesn't work with some couplers. There were some theoretical problems (stress on the coupler, not good for huge campers since it's chains, etc) but it's been out for a number of years now and not one of those has come to fruition.
So, given that I'll be using the trailer less than 10 trips a year and I don't ever have plans to upgrade to a 30+ footer, it sounds perfect for me.
(I'm in Michigan by the way. I'll update my sig one of these days.)
knuteski is offline   Reply With Quote
Old 04-10-2015, 06:45 PM   #13
Famous last words. I've had my Roo 19 for 3 years and I'm now waiting on my Mini-Lite 2503s to arrive.
In the boat world, it's called "two foot-itis."
(Let's see: 25 ft - 19 ft = 6 ft. 6 ft/3 yrs = 2 ft/yr. Yep, two foot-itis!!)
Old 04-11-2015, 08:22 AM   #14
Hicks43's Avatar
I have an e2 with the same trailer you can adjust. The head and take some of pressure out of it. As stated go big or go home
Hicks43 is offline   Reply With Quote
Old 04-11-2015, 09:55 AM   #15
Blog: RVroadtripper.com
hbillsmith's Avatar
With an Andersen it is easier to mount and dismount if you just carry a cheap torque wrench with you. Harbor Freight has a 1/2in torque socket wrench that regularly sells for $22 (its on sale know for $10). Andersen includes the socket with their hitch. The long handle of the HF wrench just makes tightening the compression chains easier. If you buy an Andersen, gononline and get the wrench too.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-12-2015, 06:23 PM   #16
I thought with the Andersen that once you've dialed everything in you just disconnect it at the other end of the chains from the ball post. And I did see that Harbor Freight deal just this morning. There's a new one close to me so I'll for sure pick one up.
Anyways, I'm definitely going with the Andersen. We brought it home today (max speed around 50 and that was just for a second to test out the sway) without any WDH and there was barely any sway. The camper wasn't level either as the hitch had a "rise" on it from when I used it with my old TV. So, any WDH would be great I think but the Andersen plenty for us.
