Old 09-22-2015, 06:40 PM   #31
Not too long ago emission testing was done with the drive wheels turning on a dynamometer at 40 to 60 MPH. Emission samples were taken at highway speeds.
mchauvet is offline   Reply With Quote
Old 09-22-2015, 06:56 PM   #32
CWSWine's Avatar
VW figured out how to detect when the emission test equipment was installed and adjusted emissions so they it would pass. In this case it didn't matter if the state had testing or not, they were even passing in California. Now the question is were the big three US makers doing the same thing. I won't put it pass any of them the way the running of the numbers in the last few years!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-22-2015, 07:31 PM   #33
I guess what I meant to say is that the EPA and CARB should have done initial testing at idle AND highway speeds.
Old 09-22-2015, 08:31 PM   #34
Originally Posted by mchauvet View Post
There are going to be some diesel powered light duty trucks where there owners might have to remove their "tuners" and restore original ECM firmware. Diesel powered vehicles are going to be watched closely from now on.
Most people that have the tuners installed will just remove them before they take them in for the inspections. I wonder about the trucks that are "rolling coal". That is a lot of smoke. I wonder what the smoke would look like pulling a fifth wheel
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 09-22-2015, 11:13 PM   #35
True, unless there is a hardware fix...
Old 09-23-2015, 05:20 AM   #36
Then someone else will make the payments, I own my truck
Old 09-23-2015, 08:01 AM   #37
The pollutant is Nitrous oxide (NOX), which in a diesel engine when the particulate emissions are reduced, tend to go up. There are several other auto manufacturers that are even worse than VW. They shouldn't have tried to cheat around the issue though. If you have a Diesel pusher motor home, some states require you to put an additive in your fuel tank to curb NOX, which I have been told can get a little expensive, and is one of the reasons we went with a gas engine in ours (at least to begin with).
Timmy Jim is offline   Reply With Quote
Old 09-23-2015, 08:24 AM   #38
I don't believe this will effect engines that run DEF. VW did not want to put DEF on there 2.0 engine, they saved 200 million by not having to install it(according to the article I read). In the same article it said the writer had talked to a Honda engineer and they could not figure out how VW could get the engine to pass the emissions without DEF.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 11-02-2015, 04:42 PM   #39
Add the SUVs and a Porsche to the list.
Volkswagen emission cheating scandal spreads to Porsche - Nov. 2, 2015
madmaxmutt is offline   Reply With Quote
Old 11-03-2015, 12:25 AM   #40
Who cares about this issue. Most owners of diesels get tunes to disable the majority of that bogus emissions crap anyway. How many posting in this thread actually own diesels?
Skyliner is offline   Reply With Quote
diesel
« WDH Question | Mpg »
