Old 03-08-2015, 08:17 AM   #1
Your Thoughts New Tow Vehicle
Just purchased a new tow vehicle 2015 Dodge Ram 2500 Hemi 6.4.
4.10 rear end. According to Dodge tow charts should be able to tow 13,000 to 15,000. We have a 2013 Flagstaff 5th wheel 8528 RKWS. Unloaded weight 7300 loaded weight is around 9300 lbs. Traded in a 2003 Dodge Ram 2500 Diesel. Was wondering if any readers out there have this setup. And what are you getting for gas mileage. Thanks for any input.
tcorl is offline   Reply With Quote
Old 03-08-2015, 08:34 AM   #2
geotex1's Avatar
Mileage will not send you over the moon with the motor and gears, but the trans helps. With your 5er and a 3/4-ton RAM, your payload is the limiting factor but since you know loaded weight you likely know your pin weight too.
Congrats on the purchase! My daily driver is a 1/2-ton RAM crew/mid-bed/5.7 HEMI/3.92s.
geotex1 is offline   Reply With Quote
Old 03-08-2015, 08:37 AM   #3
Missing Link
cyclepuck's Avatar
2014 6.4 Mega cab 3.73 pulling a 30" TT around 8500 loaded and averaged 9mpg. Truck only had a few hundred miles on it and with you having the 4.10s it should do a little better.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 03-08-2015, 08:50 AM   #4
Thanks for the input. I forgot the pin weight.
Old 03-08-2015, 09:07 AM   #5
Missing Link
cyclepuck's Avatar
List pin weight is 1100lbs and the truck is rated a little over 3k so your good there.
2014 Puma 30-DBSS
Old 03-08-2015, 01:16 PM   #6
Maron
Send a message via Yahoo to Maron
Tcor asked for gas mileage and I don't see any one giving that info?
Maron is offline   Reply With Quote
Old 03-08-2015, 01:30 PM   #7
mike.t's Avatar
cycle said 9
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-08-2015, 02:21 PM   #8
fx2
Originally Posted by mike.t View Post
cycle said 9
9 probably isn't far off. I have a 2500 with the 5.7 and 4.10 and get right about 10 with my TT at 8,300 lbs loaded.
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 03-08-2015, 02:38 PM   #9
If you don't mind me asking, what gear do you pull in and how many rpm do you turn on the highway with the 4.10's?
Scott619 is offline   Reply With Quote
Old 03-08-2015, 03:08 PM   #10
Tow vehicle
Going with a ĺ ton is always a good idea. It gives you a lot more flexibility for trailer selection in the future plus the safety factor for stopping and passing. My 2008 2500 with the Cummins gets about 12-15 mpg on the highway with the trailer and and about the same around town depending on stops and starts. The hemi is going to get 3-5 mpg less but will give you lots of power.
rthomaslyons is offline   Reply With Quote
tow vehicle
