Old 11-14-2015, 11:55 AM   #1
chabbey's Avatar
ABS light
Today when I turned the coach on the ABS light started flashing and beeping. It eventually stopped. Do I just need to add more fluid somewhere or do I need to take it in for service? Any danger to driving before addressing?
chabbey is offline   Reply With Quote
Old 11-14-2015, 01:37 PM   #2
I'll bet it's good to drive. But it's not my life, I would suggest you call Frightliner and ask, that's what there for.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 11-14-2015, 06:49 PM   #3
silver's Avatar
If the ABS light comes on you still have brakes but they will not pulse if you lick them up. If the light is out I would monitor but nothing else. We have air brakes so where would you put fluid?
silver is offline   Reply With Quote
Old 12-09-2015, 12:54 AM   #4
7 Year Class A RV'er
I used to have this same problem on a Ford chassis I had. Look on the differential and you should see a sensor with a rubber cap over the terminals. If that sensor goes bad, the system gives an error. Safe to drive, just no ABS. Sensor costs about ten bucks, five minutes to replace.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
light
