Old 05-05-2014, 09:45 AM   #1
Conquistador
AC airflow
I have a 2014 430BH my question is; the ducted air-conditioning; it seems that the air flows out of the center where the air-conditioner is and the ducts are the return; is this the proper seems to me this is backwards. Thanks in advance
randonpeters is offline   Reply With Quote
Old 05-05-2014, 09:55 AM   #2
I too had some issues with airflow until I checked to make sure the grids on each ac was closed off to divert the cool air thru the ducts. You may want to confirm these grids are closed off (look for small lever on grid).
statdoc1 is offline   Reply With Quote
Old 05-05-2014, 11:31 AM   #3
TURBS's Avatar
I concur.
TURBS
Sabre owners united!
Old 05-05-2014, 03:27 PM   #4
X2
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-05-2014, 05:31 PM   #5
The cool air coming from the center of the AC unit is the 'quick cool' feature. Like statdoc1 said, look for a lever or slide to close the louvers on the AC unit and you should feel cool air coming from the ducts.
Old 05-06-2014, 08:13 AM   #6
Conquistador
Thanks guys; I'll try that. I just noticed no flow through the ducts & seemed odd.
Old 05-06-2014, 08:23 AM   #7
Red Wolf's Avatar
My Rockwood arrived yesterday, and the AC was the first thing we turned on. The vents were blowing, but the trailer wasn't cooling. I finally noticed those intake vents were closed, and opened them up. THEN the trailer got much cooler.
Odd design, I wish there was better documentation on this stuff.
-Red
Big Bad Wolf - '15 Dodge Ram 2500HD 6.7 CTD / Reese 15k Pro
Wolf Den 3 - '14 Rockwood Signature Ultra Light 8280WS
Red Wolf is offline   Reply With Quote
Old 11-28-2014, 02:22 PM   #8
I have a gas like smell that has started to be emitted through the rear AC units. Just started happening on my '14 bh430. Anyone else had this issue?
trentkimball is offline   Reply With Quote
