Old 11-13-2015, 11:07 AM   #1
chabbey's Avatar
Adding Coolant
My low coolant light came on so I picked up some of the red antifreeze/coolant to top off the tank. Question is, do I put it into the radiator or the overflow tank? Any other things to be careful of?
chabbey is offline   Reply With Quote
Old 11-13-2015, 11:38 AM   #2
Overflow tank while cool. If you keep losing fluid, get a pressure check.
breezyhillfarm is offline   Reply With Quote
Old 11-13-2015, 03:16 PM   #3
I had the same thing happen to me last week. I discovered a loose hose clamp on the heater hose above the generator. Also you may want to check the freightliner manual for approved antifreeze. Final point: I found a small hand pump made filling the reservoir super easy.
statdoc1 is offline   Reply With Quote
Old 11-13-2015, 11:27 PM   #4
chabbey's Avatar
Love the hand pump idea...nothing is easy to access. Where do you find one?
Old 11-13-2015, 11:45 PM   #5
I have purchased several over the years. The best came from Walmart and was less than $10
