Old 01-21-2014, 06:35 PM   #1
air brakes
When I release the airbrakes on my 2010 Charleston, it is not fully releasing. When I put it in drive, it does not readily move forward. I can then go to reverse and back to drive and it does ok. Also, when accelerating, I hear a small air leak. Are the two connected? Any help appreciated.
Sanford is offline   Reply With Quote
Old 01-21-2014, 06:39 PM   #2
Ford Idaho's Avatar
Yes they are connected air brakes need air if it is leaking then there is not enough air for the brakes.
Brakes will release at or about 60 PSI but will be soft and unsafe.
What kind of pressure do you have showing?
Old 01-21-2014, 06:49 PM   #3
75 lbs plus. Any idea of where the leak could be?
Old 01-21-2014, 06:51 PM   #4
TURBS's Avatar
If you have 75 lbs + that should be plenty to fully release brakes.
Has the unit been sitting awhile?
TURBS
dog wisperer
Old 01-21-2014, 06:53 PM   #5
Setting since early November.
Old 01-21-2014, 07:00 PM   #6
Ford Idaho's Avatar
No idea at all.
How long did you let it run and build air?
Will it build air to 100-110 PSI?
Old 01-21-2014, 07:02 PM   #7
15 -20 minutes. No, it will not build up to that level.
Old 01-21-2014, 07:04 PM   #8
Capt. Mike's Avatar
You should have automatic moisture ejectors on your brake system on the coach. Is that what you hear "leaking"? They will, from time to time, "spit out" (for lack of a better term) any moisture that is in the air that is delivered from the air compressor.
In this weather, if you don't have heated ejectors, they could be freezing up, and remaining open, allowing air to bleed off. 75 psi sounds a little low for air brake pressure. Our school buses used to run higher brake pressures than that.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-21-2014, 07:04 PM   #9
TURBS's Avatar
I see this plenty.
The drum shoe surfaces rust very easily and the shoes grab tight to this rough surface and acts like brakes are applied.
If brakes are adjusted properly there's normally a minimal gap between shoe and drun surface.
Air leak may be unrelated but dont rule it out, will pressure build to over a hundred and "pop" off?
Is is relatively cold there or no?
TURBS
dog wisperer
Old 01-21-2014, 07:10 PM   #10
Ford Idaho's Avatar
Air dryer is what they are called.
https://www.google.com/#q=truck+air+dryer
Biggest problem with them is a lot of people do not bother to service them.
I would start at the air compressor and then the air cans on the brakes.
Also check the brake air tank and see if the bleeder valve is open.
