Old 01-25-2017, 12:40 PM   #1
Cab Heat
2015 Charleston RB. Has anyone had trouble getting heat from the cab heater. Mine runs cold even though the engine temp is 187. AC works fine.
frodmiller is offline   Reply With Quote
Old 01-25-2017, 12:52 PM   #2
While I don't have a clue about your unit, I have to ask if it has heater shutoff valves and are they open? Easy way to tell is feel the heater hoses and see if they are warm or cold. If warm, the other issue may be the modulator valve on the inlet side of the heater (on the firewall). It's usually cable or vacuum operated and needs to be open for the heater core to receive hot coolant and thus produce heat... The modulator valve is there to prevent the heater from fighting the ac during warm weather.
SidecarFlip is offline   Reply With Quote
Old 01-25-2017, 01:49 PM   #3
No issues with mine, but I have to have it set to maximum heat to get heat.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 01-25-2017, 01:53 PM   #4
That should not be. You might want to look at your modulation valve. They are adjustable.
