04-13-2017, 03:13 PM
Cruise control stopped working
Hey all, just pulled out to head to NYC for the weekend and my cruise control on our 2015 Charleston just stopped working. Anyone else ever have an issue like this?
04-13-2017, 03:16 PM
Kanadian Kamper
So just stopped working today, or since last time out or last year?
Checking the fuse block (wherever yours may be) is always the first place to look.
Ken and Terry
04-13-2017, 03:18 PM
Just stopped working today. Been traveling since the end of February. Been parked for a couple weeks in Syracuse.
04-13-2017, 03:24 PM
Kanadian Kamper
Could be a dirty contact in the cruise control switches....but the easiest is still to check the fuse block.
Ken and Terry
04-13-2017, 06:29 PM
So now none of the buttons on the steering wheel are working, including the horn. Ideas?
04-14-2017, 12:10 AM
Most likely the clock spring in the steering column. A rolled up set of wires that connects all the buttons to the car. If it jams it can break the delicate wires.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
04-14-2017, 01:01 PM
Not sure how the new stuff works but the cruse control systems 2-3 years ago use vacuum assist from the engine to operate. If it was sitting for several weeks you may have had some unwanted guest that were chewing on it.
Tim
04-14-2017, 01:47 PM
Kanadian Kamper
Gorlof
So what's the total count now with the steering wheel controls?
Horn doesn't work
Cruise doesn't work
Any other controls/buttons?
This sounds like a common ground lead/wire now broken. I would hazard. To say a horn and cruise are on separate fuses.
Ken and Terry
04-14-2017, 09:05 PM
Have you given Freightliner a call? They've always been real helpful to me!
04-14-2017, 10:48 PM
Try disconnecting drive battery or pull fuse to body control module
want hurt might help
04-15-2017, 08:27 AM
This is probably not your problem,,, but the cruse in out 2011 Ford EDGE quite working a few weeks back,,, dash said that the Advanced Track needed to be serviced ???
It turned out to be an Computer Update !!! EDGE has not run right since,,, rough idling when in gear,,, it is going back to dealer next week !!!
04-16-2017, 07:56 PM
No cruise, no horn, no wipers. Essentially nothing on the "smart" wheel works except steering
04-16-2017, 08:21 PM
Steering column wiring harness failure or body computer failure. I would get it into a good shop that has competent employees to work on computers or wiring.
Let Us Know What They Find Tim
04-17-2017, 06:41 AM
Maybe not a very smart wheel hey ??? Sorry could not let that go !!!
I do love all the controls on the steering wheels these days !!! and thy fact that they are back lite !!! I believe that Tim is right on about taking your unit to a Dealer !!!
GOOD LUCK Gorlof !!!
05-17-2017, 10:30 PM
I had exactly the same issue. The steering wheel needed to be replaced.
05-18-2017, 08:26 AM
I hope it was under warrant !!!
11-18-2017, 05:38 PM
Happened to me a couple years back. Opened 12 volt circuit in cockpit and re closed, that did the trick. It was a Winnebago product but all Freightliner's are the same sensitive electronics.
