As for the panel, L1 showing 120 V is correct. L2 showing 5 V is incorrect. Are you plugged in to 50 amp service? You must have 50 amp service in order for everything to work. You cannot be plugged in to 30 amp service with an adapter, won't work. If you are plugged in to 50 Amp, then something is wrong with L2, no voltage. Should be 120 V just like line 1.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
