That would generally point to battery first. I have had this problem when batteries are just a tad drained. I assume your trying to start from inside panel. Try starting at gen with the start switch. If still not cranking you have eliminated a switch problem inside the coach. To double check battery start the coach and let run a bit and try to start the gen with engine running. If your positive battery is at 12.6 or better look for. Resettable breaker/fuse that is square with a little button on side that pops out. Its usually in line from battery
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
