11-13-2015, 10:45 AM
Hot water fluctuates
Can anyone tell me the secret to consistent temperature in the shower. Some days it works great. Some days it fluctuates between hot and cold about every 20 seconds. We have the instant tank and I understand all the concepts about using the hot only and regulating based on the pressure, but even so, it's like it goes on and off. Laundry is not going and no other uses. Propane is full tank. What else can I check?
Thanks!
11-13-2015, 10:54 AM
Bypass valves?
11-13-2015, 11:08 AM
I don't think so because it is getting hot...it just fluctuates.
11-13-2015, 11:14 AM
Mine did that this morning while showing for the first 5 minutes then it acted right the rest of the shower time. Weird I thought because it never fluctuated on me before. I'll let you know if I figure anything out.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
11-13-2015, 11:36 AM
Check to make sure the valves in the outside shower are turned off ( not just the shower head). This can cause the problem you are seeing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-13-2015, 11:48 AM
Thanks for the heads up on the outside shower. I checked they are off, I'll keep looking
11-13-2015, 12:18 PM
Fluctuating water temperature is usually caused by rapidly fluctuating pressure if the bypasses are closed. Are you on public water or running the pump when it happens?
If on the pump you can add an accumulator tank to level out the pressure changes and that will probably help.
Gotta go campin!
11-13-2015, 11:25 PM
On public water and using a pressure regulator.
11-15-2015, 02:11 PM
I assume you have a Garerd gen ll. If so look at the gen lll upgrade. It is supposed to be great. I had my gen ll switched for an Atwood and are much happier.
As for what you have now. The water regulator needs to be adjustable. The cheap ones that are preset are junk and don't work with the Gerard. Get a good one with an adjustment and a good gage. Set it to 55 lbs. adjust the output so the water is to your liking. It will change as the input temp changes. If you have the gen l you really need to call and talk to Randy about getting it upgraded.
11-15-2015, 03:22 PM
How do you know which Gen it is? The model is GSWH-1
Who and where is Randy?
11-15-2015, 03:53 PM
Do you have in adjustment dial in the Moho someplace?
If so its a gen ll if not its a gen l.
Randy is the warranty / repair person at FR. He is a real good guy and will help out with these type of issues. I personally would contact Gerard and see about updating the WH to a gen lll. They are getting great reviews. I believe they will upgrade it for 300$. You will need to get the new cover painted. Check out some of the posts on the Berkshire page. Our rigs have a lot in common.
11-15-2015, 07:10 PM
I've had that happen a few times and i think it's air in the lines. I now ensure to run every faucet in the coach both hot and cold for a few minutes and doesn't happen anymore.
Jason
11-15-2015, 07:23 PM
chabbey
My gen 2 model is GSWH-1M.
I run the water pressure with the regulator set a 55psi, if you can get that pressure you can use only the hot water and have a nice warm shower, until the input water temp gets to cold, then I have to slow down the hot water to about half pressure. Not sure if the water will get hot enough when the input temp gets down below 40 degrees.
Bill
2015 Charleston 430RB
11-16-2015, 01:22 PM
I have a gen II in my Berk. Adjusting the WH is easy and needs to be changed at about every 10°-15° change in ambient temperature. The adjusting knob in the Berk is located in our medicine cabinets. Turn the shower on full hot and let it run until hot water comes out of the shower head. Adjust the knob to the temperature that you want. What you are doing is adjusting the flame height in the heater itself.
Good luck.
Paul
