Old 11-13-2015, 10:45 AM   #1
chabbey's Avatar
Hot water fluctuates
Can anyone tell me the secret to consistent temperature in the shower. Some days it works great. Some days it fluctuates between hot and cold about every 20 seconds. We have the instant tank and I understand all the concepts about using the hot only and regulating based on the pressure, but even so, it's like it goes on and off. Laundry is not going and no other uses. Propane is full tank. What else can I check?
Thanks!
chabbey is offline   Reply With Quote
Old 11-13-2015, 10:54 AM   #2
Bypass valves?
Iwritecode is online now   Reply With Quote
Old 11-13-2015, 11:08 AM   #3
chabbey's Avatar
I don't think so because it is getting hot...it just fluctuates.
Old 11-13-2015, 11:14 AM   #4
mud yapster's Avatar
Mine did that this morning while showing for the first 5 minutes then it acted right the rest of the shower time. Weird I thought because it never fluctuated on me before. I'll let you know if I figure anything out.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-13-2015, 11:36 AM   #5
Flybob's Avatar
Check to make sure the valves in the outside shower are turned off ( not just the shower head). This can cause the problem you are seeing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-13-2015, 11:48 AM   #6
Thanks for the heads up on the outside shower. I checked they are off, I'll keep looking
Old 11-13-2015, 12:18 PM   #7
Head Rambler
Fluctuating water temperature is usually caused by rapidly fluctuating pressure if the bypasses are closed. Are you on public water or running the pump when it happens?
If on the pump you can add an accumulator tank to level out the pressure changes and that will probably help.
Gotta go campin!
Old 11-13-2015, 11:25 PM   #8
chabbey's Avatar
On public water and using a pressure regulator.
Old 11-15-2015, 02:11 PM   #9
I assume you have a Garerd gen ll. If so look at the gen lll upgrade. It is supposed to be great. I had my gen ll switched for an Atwood and are much happier.
As for what you have now. The water regulator needs to be adjustable. The cheap ones that are preset are junk and don't work with the Gerard. Get a good one with an adjustment and a good gage. Set it to 55 lbs. adjust the output so the water is to your liking. It will change as the input temp changes. If you have the gen l you really need to call and talk to Randy about getting it upgraded.
Old 11-15-2015, 03:22 PM   #10
chabbey's Avatar
How do you know which Gen it is? The model is GSWH-1
Who and where is Randy?
hot water, water
