Old 06-23-2019, 12:19 PM   #1
keyless entry woes
trying to see if anyone can help 2015 charleston motorhome the keyless entry sounds like it is working but will not unlock the the door. I took the door handle cover off looking for a battery but am wondering if it is in the handle bolted to the coach its self
racer27 is offline   Reply With Quote
Old 06-23-2019, 07:59 PM   #2
I have the same coach, the only times had issues with the unlock I was able to lean on the door (hard) and it opened. Now I lube the lock with WD4 once or twice a year.
I also leave the drivers window unlocked so I can get in if it ever sticks.
Battery should be driven off the engine battery cause it still works when coach batteries disconnected.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
