Old 11-09-2015, 11:10 PM   #1
LED lighting
Is anyone having trouble with LED lighting in the Charlston? About half of my LED lighting bulbs are half light or not light.
FREE_AS_A_BIRD_NOW is offline   Reply With Quote
Old 11-10-2015, 08:24 AM   #2
Take the bedroom ceiling lights. Are all of them bright or dim?
Now slide the dimmer to see what effect it has on the lights, just some dim or some come on bright? Do the same for front living area and let us know.
It should be under warranty also. The center led don't dim.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 11-10-2015, 09:11 AM   #3
Bill, thanks for the input - however, I did adjust the dimmers to full brightness. In the bathroom where there is no dimmer - two of the larger lights are completely out after they became weak and dim. In the kitchen where there is no dimmer - I took the glass covers off the lights and all of them had a different brightness; one of which had full brightness with all of the LED bulb points within it lit while others some of the LED bulb point were not lit. It is just weird that LED's would all be bad from the git-go of a new motorhome. Thanks for your feed back! Barry
Old 11-10-2015, 06:06 PM   #4
gasman94's Avatar
If you go to the Berkshire forum, some of these guys are having problems with led's and were told they. Got a bad batch of lights. Sounds like it may be your problem.
gasman94 is offline   Reply With Quote
Old 11-10-2015, 06:46 PM   #5
dan-nickie's Avatar
See this thread:
2016 38A LED lights.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 12-21-2015, 01:11 PM   #6
Does anyone know where I buy these LEDs from?
rickhunsaker is offline   Reply With Quote
Old 12-21-2015, 08:49 PM   #7
gasman94's Avatar
Looks like amazon has a lot of choices under RV led lights.
Rich
Old 12-22-2015, 07:59 AM   #8
The LED lights should last as long as the couch according to Mike at FR. FR is replacing mine but the couch has to go there anyways. He said he would send the LED'S to me - but I opted for them to replace them when couch is taken back up. The LED'S are hard wired in so if there is many of them it is not as simple as unplugging and plugging a new one in.
Old 12-29-2015, 07:33 PM   #9
Same problem with mine. RV less than 6 months old and 4 of the LED lights are completely out, including 2 outside the bathroom so it's very dark in the hall.
josephe814 is offline   Reply With Quote
Old 04-04-2016, 06:28 PM   #10
Only problem we have had with led in 2015 Charleston is strip on awing center is out
stevevanbibber is offline   Reply With Quote
charleston, led, light
