Old 03-15-2013, 07:38 AM   #41
SkrapMoney's Avatar
Well we finally pulled the trigger after much time and research. In the end we went with a late model 2013 Birkshier. They made some upgrades to the later models as they did the Charlestons. Where very happy and cant wait to hit the road. We pick it up mid next week. We'll post some more thoughts after being on the road a few days.
Thanks for all the info and feedback from everyone.
RV safe everyone.
SkrapMoney is offline   Reply With Quote
Old 03-15-2013, 09:27 AM   #42
doughboy's Avatar
Where did you buy it from?
doughboy is offline   Reply With Quote
Old 03-15-2013, 09:34 AM   #43
SkrapMoney's Avatar
De Martini RV in Grass Valley, Ca.
Old 03-16-2013, 07:06 AM   #44
greensalsa's Avatar
Really looks awesome! Really looking forward to do the same, probably still stick with the Charleston, late this fall.
greensalsa is offline   Reply With Quote
Old 04-30-2013, 03:40 PM   #45
RV safe everyone.
What upgrades did they do mid year?
Old 05-08-2013, 01:00 PM   #46
JTN8's Avatar
I actually just ordered a 2014 Berkshire 390BH and below is a list of the changes that I got from the dealer.
-Optional wood accent dash insert.
-Full porcelain tile entry step well...used to be black metal.
-Flex Steel L-shaped sofas in select floor-plans.
-Stainless appliances.
-Hardwood cabinet trim throughout...used to only be wood in the passenger side slide cabinet trim.
-Molded bath sink...under mount now vs. mounted on top of cabinet.
-New booth dinette (larger with a solid surface Corian tabletop).
-Full coach HDMI ready. No more co-ax.
-Larger TV's
-Residential refer option on all floor-plans.
-Stack-able Washer/Dryer option on all floor-plans.
-Larger tires 275 vs. 255. This is due to the increased GVWR. They went up to 32,000lbs from 28,000lbs which gives you another 4000 lbs of cargo carrying capacity.
Hope this helps...
Jason
Old 05-08-2013, 01:20 PM   #47
SkrapMoney's Avatar
-Larger TV's
Hope this helps...
Jason
Yep this what my late model 2013 has.
Old 05-08-2013, 01:20 PM   #48
Berkshire 390QS
NO3putt's Avatar
Like the wood dash, looks to be the same configuration as our. Just makes me wonder if we could purchase from FR or their supplier and swap our out. Maybe a question for Randy at FR?
Old 05-08-2013, 01:42 PM   #49
JTN8's Avatar
How does the new HDMI upgrade work? Did they put a HD video box in so all the TV's get HD from what ever you have selected? Also do all four TV's work off the select box or is the ext tv separate? I heard that the ext tv is not hooked into the video box so u can't watch directv outside. Is this true or do you have any insight on how it all works.
Thank you
Jason
Old 05-08-2013, 02:09 PM   #50
SkrapMoney's Avatar
Thank you
Jason
Right now I have 2 cable boxes. 1 box for bedroom. The other for the 2 in living room and the 1 outside. So you have to watch the same channel on those 3 tv's.
