Old 07-18-2015, 04:20 PM   #1
chabbey's Avatar
No Air!
Help! We are headed home today from Branson in the heat. I turned the gen on while still plugged in to 50 amp shore power and then unplugged. We haven't been able to get the air back on. Keep getting E7 on the display. Tried several times. Tried resetting the panel (holding down mode and zone until Init). Air worked fine all week. Kids are crying over the heat! Can't cool the whole coach from the dash. Any other ideas how to get it running again??!
chabbey is offline   Reply With Quote
Old 07-18-2015, 04:21 PM   #2
chabbey's Avatar
Also tried flipping the breakers...
Old 07-18-2015, 04:25 PM   #3
clr
Your may have blown a fuse in your transfer switch. I would try shutting down the Gen set for a few minutes and then restarting the gen set, it may reset the transfer switch.
clr is offline   Reply With Quote
Old 07-18-2015, 04:34 PM   #4
chabbey's Avatar
Thanks. I left it off while we drove an hour then tried again. Same thing. Is there another way to reset this fuse?
Old 07-18-2015, 05:26 PM   #5
clr
Your error code on the thermostat means that the AC or not receiving 120v. The transfer switch is automatic and the gen set should have taken priority over the shore power. But by switching under heavy load you may have done something to your transfer switch.
Old 07-18-2015, 06:10 PM   #6
Did you check the two breakers on the gen set itself?
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 07-18-2015, 06:43 PM   #7
chabbey's Avatar
Breaker on the gen! That was it! Thank you!!! My family loves you!
Old 07-18-2015, 09:13 PM   #8
Question, were you running all 3 A/C's when you had the gen running and unplugged shore power?
My sales guy told me it would blow the gen breaker and I thought he was kidding.
Bill
Old 07-18-2015, 09:21 PM   #9
chabbey's Avatar
We only have 2 (on the 2012), but yes, they were both running!
