Old 05-18-2015, 08:42 PM   #1
chabbey's Avatar
No hot water
Trying to get ready for the season but not getting any hot water. Propane is on (have 1/4 tank). Switch on Gerard unit is on. When I run hot faucet, light on unit comes on, blower blows but nothing gets hot. There's no pilot to light is there? I don't smell any propane. What am I missing?
2012 Charleston BHQS
6 people & a dog!
Towing 2013 Ram or 2014 Durango
chabbey is offline   Reply With Quote
Old 05-18-2015, 08:47 PM   #2
chabbey's Avatar
Name:	ImageUploadedByForest River Forums1432000030.190316.jpg
Old 05-18-2015, 08:57 PM   #3
lacecl2014's Avatar
Some time i have the same problem. Read the attached document. You have to reset the limit switch if you have GIRARD TANKLESS WATER HEATER. Hope that will help you.
Claude
2015 Charleston 430FK
lacecl2014 is offline   Reply With Quote
Old 05-19-2015, 11:49 PM   #4
chabbey's Avatar
Thanks lacecl2014. I feel really stupid, but how do I find these "switches" and how do I reset them? The picture on the doc just confuses me. Maybe I have a different model.
I can hear the igniter going on and off, but nothing ever gets hot at all. Is there a way to test if propane is actually getting to the unit?
Old 05-19-2015, 11:50 PM   #5
chabbey's Avatar
Model is GSWH-1
Old 05-20-2015, 08:50 AM   #6
lacecl2014's Avatar
Hi chabbey
I have the same model but the set up look different. I put a picture of my GSWH-1 limit switch. My motorhome is a 2015. We are talking about a switch but it is not really a switch that you have to reset. Just press on the white buttom as you could see on the attached picture.
Claude
Old 05-20-2015, 08:51 AM   #7
lacecl2014's Avatar
Picture of my Limit switch
ID:	77519   Click image for larger version
Claude
Old 05-20-2015, 11:40 PM   #8
7 Year Class A RV'er
Our's had a problem when it was new that you might check for. If you pushed the reset button, you hot hot water until you turned off the faucet. The next time you turned on the water....no hot water. Turned out to be a flow sensor that was bad. When I shut off the water, it would kick the reset. Took a part they ordered and about twenty minutes for them to fix.
2015 Legacy SR340 360RB
Old 05-21-2015, 11:12 AM   #9
chabbey's Avatar
Ok, I guess I'm going to have to take it in to get serviced. There are no white switches on my unit, only black; and none of them have a button on them. Ugh, there goes more $$....
Old 05-21-2015, 11:01 PM   #10
chabbey's Avatar
So I found the problem. Dealer had replaced my defective CO2/LP detector last fall with the wrong one. Because it only had two wires, it automatically shut off the propane. Nothing was wrong with the hot water heater...it was just a symptom!
Thanks guys for the other troubleshooting though...I still learn something every time!
hot water, water
