Old 03-26-2016, 08:37 AM   #11
The heater is a Atwood tankless.
FREE_AS_A_BIRD_NOW is offline   Reply With Quote
Old 03-26-2016, 09:50 AM   #12
edgewant's Avatar
Not sure about the Atwood. Girard recommends that you go to each faucet and purge both hot and cold. That includes the outside shower. Air in the lines prevents the flow switch from detecting water flow properly. If the Atwoods are like the Girard and have a sail switch (it detects that the cooling fan is on) it could also be the culprit. But as previously mentioned you should start with the reset button.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 03-26-2016, 02:37 PM   #13
Are you connected to city water? The Attwood tankless will not fire if insufficient water flow is detected.....can't be certain, but I think it needs 1.5 gpm before it will fire. Also this heater is subject to a recall, check with Attwood to see if yours is on the list. We had plenty of issues with ours, but Attwood stood by the product and some new parts its now working as advertised.
Bob and Veronica
2015 Forest River Charleston 430 RB
2017 GMC 1500 Denali
Harley2152 is offline   Reply With Quote
Old 03-26-2016, 05:34 PM   #14
Harley2152, is yours the Atwood OD-5001CW? I haven't received any recall notice. But b I will check n itbout. Last year when we picked it up new from dealer we did not have hot water and they had to replace a relay I think it was. I'll call dealer on Monday.
Old 03-26-2016, 05:36 PM   #15
And no I am not hooked to city water. Using the tank and water pump. When you turn on a hot water faucet it sounds like the heater is working. The blower kicks on but stays on even when you turn hot water faucet off.
Old 03-26-2016, 06:08 PM   #16
No hot water on 2016 Charleston
Yes that is the heater we have. Not surprised you didn't receive a recall notice. Feel free to PM me and I can fill you in on how we got ours to work after many calls to Attwood.
Bob and Veronica
Old 03-26-2016, 06:10 PM   #17
Ford Idaho's Avatar
Harley you really should remove that number from an open forum, send it in a PM...
Old 03-30-2016, 11:45 AM   #18
We just purchased a 2016 Charleston 430RB and having intermittent issues also. It has an Atwood as well. When we purchased our coach we were able to stay in it at the dealership for a couple of days to test everything out. The first night we had no issues running of the freshwater tank and pump. The second night we where moved to one of there spots that had city water and was using a 40psi water regulated and had issues with it staying warm, but worked fine using both city and the water pump.
The dealership robbed one from another coach (same model) and said it was fixed so we went home. Same problem occurring. It seems to be low water pressure causes the issue. I contacted Forest River about the recall and they said to contact Atwood.
I will contact Atwood today and post my findings here.
mib2nd is offline   Reply With Quote
Old 03-30-2016, 12:24 PM   #19
Thanks!
Old 03-30-2016, 01:48 PM   #20
I have the contact information of the customer service rep Attwood who was instrumental in getting our water heater to work correctly ...as I've learned, PM me if you want her contact info....best of luck!
Bob and Veronica
charleston, hot water, water
