Old 03-25-2016, 07:24 PM   #1
No hot water on 2016 Charleston
Does anyone have any ideas on why hot water will not work? Ignite failure light is off and not on. We had hot water last year but after winter now no hot water.
FREE_AS_A_BIRD_NOW is offline   Reply With Quote
Old 03-25-2016, 07:26 PM   #2
Ford Idaho's Avatar
What kind of shape are the batteries in?
Old 03-25-2016, 07:30 PM   #3
I am running generater and everything else is working. Heat pump on hot water blowing cold air out of vent.
Old 03-25-2016, 07:31 PM   #4
Before I started genie I had plugged into shore power.
Old 03-25-2016, 08:07 PM   #5
Your hot water heater by pass isn't on is it?
CTGREG is offline   Reply With Quote
Old 03-25-2016, 08:43 PM   #6
Where is the bypass and I'll check? Shouldn't be cause I have touched anything since closing it down last fall.
Old 03-25-2016, 08:51 PM   #7
edgewant's Avatar
What kind of water heater is it? If Girard tankless you need to make sure all the air is purged from the water lines.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 03-25-2016, 09:24 PM   #8
Director, FROG
F.R.O.G.'s Avatar
There's a tiny reset button near the upper left of this picture. The top end of the purple wire is attached to it. Open the compartment and press that button (it will barely depress) then have someone turn on the hot water at full force. The burner should light.
When you put the panel back on, make sure the air intake pipe (attached to the copper elbow just to the right of the center of the photo) is lined up with the hole in the panel so that you're not blocking air going into the heater.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 03-25-2016, 09:33 PM   #9
Thanks... I try it!
Old 03-26-2016, 08:10 AM   #10
Edgewant, what would happen if all air was not purged before I tried to turn on hot water. I may have tried to purge using hot water valve in sink. Reading up on dewinterizing it did not say use cold water first but turn on both hot and cold valves. Could this be an issue? I know it is purged now... and when I turn on hot water valve I can hear water going to heater and blower at heater is on but only cold air coming from blower.
charleston, hot water, water
