Old 06-19-2016, 04:19 PM   #1
JimNix's Avatar
Tag axle operation question
I searched and googled, but could not find an answer to this.
I have purchased earlier this year a 2015 Charleston with tag axel.
When you dump the tag, does it auto fill after some predetermined time?
The rocker switch only goes one way, so you don't have the option of toggling the switch back (like "on" or "off").
Any thoughts on this?
2015 Charleston 430RB
2000 Jeep Wrangler
JimNix is offline   Reply With Quote
Old 06-19-2016, 04:53 PM   #2
BamaBob's Avatar
I am assuming it is like the Berkshire XLT - if so, yes it will auto fill.
What are you dumping it for? You have the ultrasteer, correct?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-19-2016, 05:52 PM   #3
JimNix's Avatar
I have a Charleston, 2015... No ultrasteer...
Dumping for tight cornering, in town or at the campground... This is what I was told to do...
2000 Jeep Wrangler
Old 06-19-2016, 07:04 PM   #4
Yes it auto fills after you get up to 8 mph, I believe. The manual tells you but I guess they did not leave the manual for you....bummer.
For a normal turn I do not dump the tag, tires have no problem with that, I do dump when in a campground and going around tight turns or a filling station. I' m only running 7500 lbs on tag with toad..
Bill
Billr is offline   Reply With Quote
axle
