Old 06-22-2017, 02:32 PM   #1
Trapless shower drain bad odor 2015 charleston
Bad odor from shower drain. I need to replace trapless drain. Does anyone know the brand or part number.
frodmiller is offline   Reply With Quote
Old 06-22-2017, 05:00 PM   #2
clr
I have never seen a camper with a trap less drain, but of course that does not mean that yours does not have one. Most campers have a vent less arrangement for some of their drains and if the venting device goes bad it will cause a stink. The venting device is attached to the drain plumbing as high as they can place it, so look for a normally black device attached to the drain plumbing. You should be able to unscrew it to remove. It is basically a check valve. Found that they are called an air admittance valve.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-23-2017, 11:42 AM   #3
camping world sells them
cfo111 is offline   Reply With Quote
Old 07-08-2017, 08:38 AM   #4
Just replaced mine also for the same reasons. You can usually find them at a plumbing store in the section where ABS pipe is. Grab two they are cheap.
Changing it up a bit
2017 40 ft Cardinal Estate
2014 SRW Chev Duramax 3500
Titan 50 gal fuel tank
Air Lift 7500 lb bags
changing it up a bit is offline   Reply With Quote
Old 07-08-2017, 08:41 AM   #5
BandJCarm's Avatar
Studor valve.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-08-2017, 08:48 AM   #6
Originally Posted by BandJCarm View Post
Studor valve.
That is completely different than a trapless drain or waterless trap.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-08-2017, 09:01 AM   #7
Correct! HEP^O makes a RV waterless Drain Trap! Youroo!!
Old 11-18-2017, 05:01 PM   #8
VinceU's Avatar
Normally you don't need to change them, just clean with strong bleach and water. Let soak for 30 minutes and flush.
Old 11-19-2017, 09:22 AM   #9
50 50 bleach and water soak like VinceU said they work very well been out for a number of years they are now being used in homes with clearance problems.
charleston, drain, show, shower
