Old 09-17-2016, 01:19 PM   #1
chabbey's Avatar
Voltage Issues
Can anyone tell me what this means on the message center?
AUTO IDLE
SYS VOLTAGE 12.0V
THRESHOLD 13.4V
It started showing this after a fill up and 1/2 hour lunch. Getting back on the road, it kept flashing
BATTERY
LOW VOLTAGE
Then the Check Engine light came on.
I thought the battery wasn't used after starting. And this battery is only a few months old.
Any insight my friends?
chabbey is offline   Reply With Quote
Old 09-18-2016, 10:22 AM   #2
Time to call. fcccservice@daimier.com
(800) 385-4357
They should know. If you have a volt meter, check the battery voltages on both banks of batteries just to be sure.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 09-19-2016, 12:44 PM   #3
ceedog's Avatar
I get the low voltage warning on my Berk. It goes away after a few minutes. When I as at the factory in 2015, Randy & crew said not to worry about it. It's just a quirk of the charging system.
It ain't easy being me...I've tried.
ceedog is online now   Reply With Quote
Old 09-19-2016, 02:16 PM   #4
chabbey's Avatar
Unfortunately it doesn't go away for me. The more items I have using the electrical system (GPS, radio, A/C, map light, etc), the more it keeps beeping.
And if I let it idle, it ramps the idle up pretty high. I hit the brake to put it back down, but in 30 seconds, it's back up again.
I'm pretty sure this is something I should address.
Old 09-19-2016, 02:22 PM   #5
I've seen 2 month old batteries drop cells and quit charging. These were the expensive batteries from Napa. Load tester would help with your diagnosis as well as charging output voltage.
2017 Rockwood MiniLite 2506S
2019 GMC Sierra 6.2L
2017 Colorado D-Max pulling 2017 Tracker 175TXW
Days Camped in 2017: 71
Days Camped in 2018: 37
Days Camped in 2019: 15
bshort is offline   Reply With Quote
voltage
