Old 11-16-2016, 10:01 PM   #1
Water leak in manifold bay
2015 RB Charleston, slight water leak in manifold bay. Water seems to come behind plywood wall where outside shower hangs. If you have this issue or 2015 or 2016 run your hand behind that wall an see if it's wet . I found a 2016 that's wet, I think it's fresh water tank leaking, possibly at a seam, anyone have this problem ?
SEAYALL is offline   Reply With Quote
Old 11-17-2016, 04:28 PM   #2
No leak issues on my 2015 RB and I'm living in it.
This will be my first winter in it and a little worried about pipes freezing, I'm good in the water bays but the water to the fridge may freeze and the lines that run under the bed. First hard freeze is Sunday morning.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 11-26-2016, 03:37 PM   #3
Problem solved, thanks Warren, FR Tech
leak, water, water leak
