Old 01-27-2018, 01:33 PM   #1
Winegard Trav'ler Box
I am in the process of getting my satellite's/TV set up, as from a previous thread I was able to locate the coax cables and identify same. Now, my question is...the Winegard trav'ler box was unplugged and in the bottom drawer under the dinette.
I do not know where it should actually be located as I cannot find the interface wire?? Any guidance would be greatly appreciated!
Sean
Sean Brown
2013 Charleston 430bh
Sean Brown is offline   Reply With Quote
Old 01-27-2018, 01:54 PM   #2
There should be a 5 wire cable that plugs into the control box. There should also be a power supply that plugs into 120VAC and into the correct port on the control box. Coax, depending on sat service the dish is setup for will either go directly to the back of the reciever or to the power inserter.
If you cannot find the control cable, you probably need to go up on the roof and verify one is actually connected to the Travler. If its there, follow it across the roof to where is drops down. Go inside, locate where it drops down and look.
donniedu is offline   Reply With Quote
Old 01-27-2018, 02:25 PM   #3
Thanks....checked the roof...all of the wires are tired up there (coax and control cable)...I guess they never finished the job?!
Thanks again!
Sean Brown
Old 01-27-2018, 02:38 PM   #4
Time to figure out where you can drop the cables then. Find a convenient spot drill as small a hole as you can and go.
winegard
