Old 07-25-2016, 02:15 PM   #21
asquared's Avatar
site team reminder: Please do not engage in the nitrogen tire debate. The OP wants to know the location of where to obtain it. Not the pros and cons debate. Please stay on topic. Thank you.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-25-2016, 02:20 PM   #22
asquared's Avatar
To get weighed, go to any truck stop with a scale. Check CAT Scale | Network of Certified Truck Scales. for a location near you. When asked for your rig number, tell them private vehicle. Then pull around and pay. I usually weigh the truck front axle on scale pad 1, rear axle on scale pad 2 and all trailer axles on scale pad 3. I then pull into a parking spot and unhook, go back and weigh just the truck (same scale pads as before). Typically first weigh is $9-12 and any reweigh in a 24 H&R period at the same scale is $1-3.
If you are attending the factory rally, there has been a company that will weigh each individual tire for you in the past. I am not sure of cost or if they will be there this year.
2014 Sabre 34REQS-6
Old 07-25-2016, 02:24 PM   #23
You can pull the tire off and carry it into most any car dealer ship. I am sure they will be happy to help you.
When tires are filled with nitrogen there is not a vacuum pump that is connected like an ac system. It is simply letting the air out of the tires then filling with nitrogen. This adds enough to help prevent the temperature from fluxuating tire pressure but fluctuation still exsists because no one vacuums all the air from the tire in the first place.
With that being said. Put some air in it. There is already air mixed with the nitrogen fill anyway.
As info
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
2014 Jeep SRT...did not trade
Simplewon is offline   Reply With Quote
Old 07-25-2016, 02:28 PM   #24
GreenImp's Avatar
Send a message via MSN to GreenImp
Originally Posted by Scheinin View Post
I am in the Dearborn area of Michigan heading west. I am 7 pounds low on my nitrogen 36CKTS 5th wheel tires (recommended psi is 110). Anyone know where I can top off? I am 40ft long plus truck, so going to car dealer won't work. I see I am not too far from Goshen, Indiana. Can I go for a fill-up at the Forest River Plant? I would also like to get my 5th wheeled weighed. Does anyone know if I can do that there?
Visit the link below and input your zip code. They will list all registered nitrogen dealers within 100 miles.
http://www.getnitrogen.org/
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 07-25-2016, 02:32 PM   #25
Check with fire extinguishing services.They service gas stations and the like with powder fire extinguishers. They must be checked every year and every 6 years blown off and refilled. They use Nitrogen to pressurize the cylinders. My son carries nitro tanks in his service truck to do the job on site. Some outfits have units that make their own nitro on board.with hoses long enough to reach Rv's etc.
Mark1 is offline   Reply With Quote
Old 07-25-2016, 02:35 PM   #26
More popcorn please!!
Old 07-25-2016, 02:43 PM   #27
BamaBob's Avatar
Originally Posted by asquared View Post
<SNIP>
As I recall, the cost is $60 (or was for our 5th wheel & truck) it may be more or less depending on how many wheels need to be weighed
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-25-2016, 02:55 PM   #28
If you are around a NASCAR track they have it in the pits Tell them Tony sent you! Youroo!!
Old 07-25-2016, 05:23 PM   #29
raytwntrvlr's Avatar
NM
2015 Flagstaff Super V 26VFKSS Emerald
2013 RAM 2500 CC 4X4 6.7 CTD
Sold... 2013 Shadow Cruiser 260BH
raytwntrvlr is offline   Reply With Quote
Old 07-25-2016, 05:24 PM   #30
BandJCarm's Avatar
Any local tire shop, that sells tires, will have it.............
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
