07-25-2016, 01:15 PM
#21
site team reminder: Please do not engage in the nitrogen tire debate. The OP wants to know the location of where to obtain it. Not the pros and cons debate. Please stay on topic. Thank you.
2014 Sabre 34REQS-6
07-25-2016, 01:20 PM
#22
To get weighed, go to any truck stop with a scale. Check CAT Scale | Network of Certified Truck Scales. for a location near you. When asked for your rig number, tell them private vehicle. Then pull around and pay. I usually weigh the truck front axle on scale pad 1, rear axle on scale pad 2 and all trailer axles on scale pad 3. I then pull into a parking spot and unhook, go back and weigh just the truck (same scale pads as before). Typically first weigh is $9-12 and any reweigh in a 24 H&R period at the same scale is $1-3.
If you are attending the factory rally, there has been a company that will weigh each individual tire for you in the past. I am not sure of cost or if they will be there this year.
2014 Sabre 34REQS-6
07-25-2016, 01:24 PM
#23
You can pull the tire off and carry it into most any car dealer ship. I am sure they will be happy to help you.
When tires are filled with nitrogen there is not a vacuum pump that is connected like an ac system. It is simply letting the air out of the tires then filling with nitrogen. This adds enough to help prevent the temperature from fluxuating tire pressure but fluctuation still exsists because no one vacuums all the air from the tire in the first place.
With that being said. Put some air in it. There is already air mixed with the nitrogen fill anyway.
As info
07-25-2016, 01:28 PM
#24
Originally Posted by Scheinin
I am in the Dearborn area of Michigan heading west. I am 7 pounds low on my nitrogen 36CKTS 5th wheel tires (recommended psi is 110). Anyone know where I can top off? I am 40ft long plus truck, so going to car dealer won't work. I see I am not too far from Goshen, Indiana. Can I go for a fill-up at the Forest River Plant? I would also like to get my 5th wheeled weighed. Does anyone know if I can do that there?
Visit the link below and input your zip code. They will list all registered nitrogen dealers within 100 miles.
http://www.getnitrogen.org/
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
07-25-2016, 01:32 PM
#25
Check with fire extinguishing services.They service gas stations and the like with powder fire extinguishers. They must be checked every year and every 6 years blown off and refilled. They use Nitrogen to pressurize the cylinders. My son carries nitro tanks in his service truck to do the job on site. Some outfits have units that make their own nitro on board.with hoses long enough to reach Rv's etc.
07-25-2016, 01:35 PM
#26
More popcorn please!!
07-25-2016, 01:43 PM
#27
Originally Posted by asquared
<SNIP>
As I recall, the cost is $60 (or was for our 5th wheel & truck) it may be more or less depending on how many wheels need to be weighed
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
07-25-2016, 01:55 PM
#28
If you are around a NASCAR track they have it in the pits Tell them Tony sent you! Youroo!!
07-25-2016, 04:23 PM
#29
Senior Senior Member
NM
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
07-25-2016, 04:24 PM
#30
Any local tire shop, that sells tires, will have it.............
FROG AR-0019-242
07-25-2016, 08:38 PM
#31
There is a CAT scale on I-275, first exit north of I-94 and a couple more farther west on I-94.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
07-25-2016, 08:45 PM
#32
... and if it's a local tire shop that doesn't sell tires, you may find their nitrogen suspect!
07-25-2016, 09:06 PM
#33
Global Nomad
Your information was helpful
Thank you to those that gave me answers to my question. I ignored those with sarcastic remarks. I did go to the web site suggested. I will also stop at Cosco.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
07-25-2016, 09:37 PM
#34
If your going to ignore those with sarcastic remarks on here, you're going to be a lonely guy.
Those folks mean no harm. Sure there' a few jokers on here, but overall good folks just trying to help. Hey I actually learn stuff with those debates. I'm by far no expert at this RV thing so it's all good.
RMc
07-25-2016, 09:54 PM
#35
Not saying it is my fault but in touring the NASCAR pits in the late 80's I asked why they were using compressed air tanks for driving air wrenches, tire pressure adjustments etc. Getting a "Huh" look I mentioned that nitrogen was a lot cheaper probably had more capacity per tank and a very slightly different pressure change versus temperature change. Seems like it wasn't long before the change was made.
07-26-2016, 04:40 AM
#36
Originally Posted by bikendan
Ditto!
I agree, Nitrogen has no real benefits unless you are using it in tires for a race car.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
