Old 08-19-2015, 12:18 AM   #1
12 volt receptacle
Could somebody tell me if there is a 12 volt recep in the bedroom for a Cpap manchine?Thank you
Ronman is offline   Reply With Quote
Old 08-19-2015, 12:21 AM   #2
SYE
SYE's Avatar
I have not found any, so I installed one myself that wat I could plug in an inverter to run my CPAP machine when I am sleeping in a truck stop or rest area. Similar to this one
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 08-19-2015, 09:05 AM   #3
Frank & Eve's Avatar
We have a 12volt plug (cigarette lighter plug) just before going to the bedroom of our 3011. We plug a small 600 watt inverter in, to plug the CPAP into, when not on shore power or generator power. Works perfectly.
Sent from my MB886 using Tapatalk
Frank & Eve is offline   Reply With Quote
Old 08-19-2015, 09:16 AM   #4
joy-rick's Avatar
I was able to purchase a 12 vdc adapter cord for my CPAP machine. That way I don't have to use an inverter if I don't have 120 vac available. This is probably a better option because of the inherent power loss in an inverter. The adapter cord is long enough to reach the living room 12 vdc outlet from our bedroom. We don't dry camp so this is only for emergencies when 120 vac is not available.
Rick (K8RWG), Joy, and Daffy (the spoiled Calico cat)
2014 Rockwood 8315BSS
2016 F250 SC LWB 4x4 6.2 3.73
Reese Dual Cam
Honda EU2000i
joy-rick is offline   Reply With Quote
Old 08-19-2015, 12:47 PM   #5
Thank you everybody for your replies.
Old 08-19-2015, 12:53 PM   #6
Not that difficult to add one. Auto parts stores have them and there is 12v running all over rvs, just tap into a line and it's a done deal. Just make sure you wire the ground wire to the receptacle case and NOT the center post.
Old 08-19-2015, 03:31 PM   #7
Class C Representative
Joshua Cavitt's Avatar
Do CPAP machines come with a 12v adapter for people who RV or is it an aftermarket purchase?
Joshua Cavitt is offline   Reply With Quote
Old 08-19-2015, 03:57 PM   #8
Crockett's Avatar
if they still use a 12volt recpt in the tv antenna area, I would advise hard wiring in a separate heavy metal recpt for the cpap instead of that one for the tv. they are too light of duty...
edit...ive been installing inverters for people. mfgs need to consider this growing market.
Crockett is offline   Reply With Quote
Old 08-19-2015, 06:18 PM   #9
Wait till next year...
n-e-d's Avatar
A lot of them do now, some wth battery pacs
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 08-26-2015, 09:31 PM   #10
Citrus County, Fl.
GL1800Rider's Avatar
Josh, they do not come with a 12 volt adapter with exception of the tiny little portable that is not designed for nightly use. After market adapters are available for some of the older machines. Most of your newer cpap machines are now dc powered and have a converter to go from ac to dc but not all are 12 volts dc. Hope this helps. Some have battery packs available but they are extremely expensive.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-26-2015, 09:48 PM   #11
coupevillefish's Avatar
Actually, the ones my wife have had were 12v based. The 110v transformers we normally use put out 12v to the CPAP. Therefore, we were able to find 12v utility cords for about $50. This allows us to use them on a 12v battrry, either from the coach or a backup battrry. You have to find the cord v that works with your CPAP.
We prefer the backup batteries rather than drawing down the coach battery.
coupevillefish is offline   Reply With Quote
12 volt
