Old 05-30-2016, 02:42 PM   #11
Rich.M's Avatar
I have the stabilizer jacks on our 24r, same as your model mbs. They definitely stop rocking when parked and we always put them down when back at the campsite for the night. Very convenient to have them powered for fast set up. I would purchase them again . The jacks on my 2015 are mounted a little further to the back than the newer models making it hard to compare. Hopefully someone with a 2016 r version can comment. 1600 is about the right price for that upgrade.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is online now   Reply With Quote
Old 05-31-2016, 06:56 PM   #12
2017 Sunseeker MBS2400WS
Originally Posted by Rich.M View Post
I have the stabilizer jacks on our 24r, same as your model MBS. They definitely stop rocking when parked and we always put them down when back at the campsite for the night. Very convenient to have them powered for fast set up. I would purchase them again . The jacks on my 2015 are mounted a little further to the back than the newer models making it hard to compare. Hopefully someone with a 2016 r version can comment. 1600 is about the right price for that upgrade.
When we ordered our Sunseeker, we ordered it pretty much loaded so to speak and had the rear stabilizers added. First off they are too far inward and close together to be used for leveling nor are they designed to lift the rear tires off the ground. But they do a fine job of taking the side to side sway caused by movement inside due to changes in rear spring loading.
Alhough Forest River does not offer the Bigfoot 4 point stabializer system on the MBS Sprinter, most likely due to weight concerns. Bigfoot does offer a complete system and also sells the front stabilizers for the MBS chassis along with the four point leveling controller.
If you do a search, you will find an article by a person who installed the front stabilizers in his driveway. It was a three day process for him
Considering the price of the four point automatic system for the MBS is almost $3900 plus installation from a Bigfoot dealer, $1600 is pretty reasonable for the two point manual system option.
www.bigfootleveler.com
Sherman
BTW, one thing I have noticed is that not even the stabilizers nor the springs will keep the new 2400W level when the full side slide out is extended. The weight of the slide out itself lets the motorhome list to the drivers left a few degrees. Due to this I am considering a pair of slide out jacks.
We have the luxury of having room and weight capacity available in our enclosed motorcycle transport trailer should I find a set that works.
ShermanD is offline   Reply With Quote
Old 05-31-2016, 07:13 PM   #13
Bluepill's Avatar
Something to consider: Your usage.
If you move about to different sites often, electric will save you more time. If you spend a week or two at sites, you will not be setting up as much.
2008 Itasca Meridian 37H
Old 05-31-2016, 08:12 PM   #14
dukeboone's Avatar
I have them on my 2016 2401S and I personally appreciate the stabilization they provide. If I'm slightly low on the rear they will help level but only slightly as they are not intended to function as leveling jacks. Some owners who have installed sumo springs think they are unnecessary with the sumos, but I don't share that opinion. The jacks do a much more thorough job of taking out the sway. On the other hand they are hefty and not having them would improve the cargo carrying capacity.
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 06-03-2016, 01:36 PM   #15
Stablizer vs. leveling jacks
Should be an easy question for a dealer service department, sales people will sell you anything. My 5er had electric stabilizer jacks in the rear and landing gear in the front - still had to put planks under the tires to get level. The back stabilizers just barely touched and stopped.
New 5er has 4 leveling jacks, each has it's own drive motor. Love pushing one button and watch the gyrations to get level, even lifts the tires off the ground.
There is a difference between stabilizing and leveling. Save money and buy a high torque cordless drill/impact and a socket to match your scissor jacks.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 06-03-2016, 01:59 PM   #16
dukeboone's Avatar
I don't believe the motorhomes in question typically have scissor jacks, nevertheless thank you for your input.
Old 06-03-2016, 02:13 PM   #17
There is a difference between leveling and stabilizing jacks - individual drive motors and the weight they can support. Where jacks are located also matters for weight distribution on the frame. I had the wrong impression about Class A/C stabilizers/jacks and their ability to stabilize the vehicle.
DJsFolly
Old 06-07-2016, 11:03 PM   #18
MNtraveler's Avatar
With our 2401R (2016), the rear stabilizers have been quite good. Maybe the R model makes better use of them than the W because the R extends more out the rear whereas the W extends more to the side and the stabilizers are towards the center of the chassis (side to side, that is). There is a significant difference in the amount of bounce and wiggle between having them down and not. Also, they can raise the rear of the unit up to about "three inches" according to the leveling guides that we installed (those are amazingly helpful). In other words, the level may indicate you need plus two inches on the rear - no problem, this will take care of it. Of course, they won't help you at all if you need +2" on the front. In that case, use leveling blocks and then just put the stabilizers down until they hit ground to, well, stabilize.
Even with the stabilizers being in the rear, there is not that much bounce in the front of the unit when moving around because the front springs are quite firm. However, there is a noticeable wiggle when someone comes in or out the front door. The amount of this might be variable by a person's weigh.
Soon we will be on a trip where we will be parked in one site for four days. I'm thinking of taking out the Mercedes-Benz bottle jack (below the floor on the passenger side on the MBS units) and placing it under the frame on the passenger side to see if this helps kill off that little movement.
A number of people have suggested getting the 4-way leveling jacks on the MBS units. However, there is already a limited cargo capacity, so adding that additional weight is really not in the cards unless MB increases the capacity of its Sprinter chassis. Until then, leveling blocks will be needed.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
jacks
