02-14-2014, 07:19 AM
2 keyed locks on coach door ?
Sorry if this has been covered before. Our entry door to the coach has 2 locks. The one on the left is the one we use. The other one we have no key for. Wonder what this lock is for ?? Maybe like a dead bolt ?
02-14-2014, 07:24 AM
Usually, one is a latch lock and the other is a deadbolt. They are also usually keyed alike. If they both don't work with one key, there is probably something defective.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
02-14-2014, 08:39 AM
X2. If you can't lock/unlock it with the same key there might be something wrong with the lock. Can you put the key all the way in like you can with the other lock?
02-14-2014, 08:51 AM
Yes I believe so but the key doesn't turn.
02-14-2014, 08:55 AM
Did you buy this unit new or used?
If used it is possible the owner changed one lock but not the other.
Spray some kind of penetrating oil into it and let it sit for awhile then try the key again
02-14-2014, 09:01 AM
I'll try that after work today and see if that works. Got the unit used but only a few months old.
02-14-2014, 09:09 AM
Age notwithstanding, I changed out both locks on my 2014 due to a recall I had it about 2 months I think.
02-14-2014, 09:45 AM
02-14-2014, 09:52 AM
My salesman told me that they are both keyed so the deadbolt key will work on both the latch lock and the deadbolt. But he also said that we should always lock the deadbolt because all people that have worked at an RV sales place would have a key that will open the latch lock but not the deadbolt. They key them this way so while on the lot, everyone can have access that needs access with only one key.
2014 Flagstaff 27RLWS
2007 Dodge Ram 1500 4x4, 5.7L
02-14-2014, 09:59 AM
True and correct.
And that would include the newer ones involved with the recall.
There are options out there if you want to pony up the bucks.
02-14-2014, 10:49 AM
Old Enough to Know Better
Will the door key slide into the other one? On my V-Cross PO had broke a key in the dead bolt and the door key wouldnt slide all the way in. I disassembled the lock but the cylinder was fubar, I intended on replacing and re keying but sold it before I could get it done. If you bought it from a dealer see it they will "fix" it
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
02-14-2014, 10:51 AM
I just changed all my locks for storage and the door......... Had a locksmith key them alike, changed to barrel locks, harder to pick !!
02-14-2014, 10:53 AM
Anacortesians
My '02 Georgetown uses two separate keys. They're significantly different.
Frank and Eileen
No longer RVers or FR owners
FYI "picking" an RV lock takes to long.
02-14-2014, 06:39 PM
My 2012 Sunseeker has two different keys that are not interchangeable.
2012 Forest River Sunseeker 2300 Chevy
02-14-2014, 06:51 PM
At what point in model years did one key do both locks. We have two keys. Always only tried each key in its own lock. Wonder if just one key will do both locks. We have a 2013.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
02-14-2014, 06:58 PM
Can you see any difference between the two by holding them together?
02-14-2014, 09:05 PM
I've had two keys since I bought my first unit in 1998.
02-15-2014, 07:40 AM
Yes. Guess that answers my question.
02-16-2014, 01:07 AM
Commercial Member
They are not keyed alike...not sure what the point to that would be.
One key is for the latch. A master key exists for that.
Second key is for the deadbolt. That does not have a master.
PS. This is a Forester sub-forum. Not the same locks as trailers in most cases.
