Old 02-14-2014, 06:19 AM   #1
Frank & Eve's Avatar
2 keyed locks on coach door ?
Sorry if this has been covered before. Our entry door to the coach has 2 locks. The one on the left is the one we use. The other one we have no key for. Wonder what this lock is for ?? Maybe like a dead bolt ?
Frank & Eve is offline   Reply With Quote
Old 02-14-2014, 06:24 AM   #2
Usually, one is a latch lock and the other is a deadbolt. They are also usually keyed alike. If they both don't work with one key, there is probably something defective.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-14-2014, 07:39 AM   #3
X2. If you can't lock/unlock it with the same key there might be something wrong with the lock. Can you put the key all the way in like you can with the other lock?
Old 02-14-2014, 07:51 AM   #4
Yes I believe so but the key doesn't turn.
Old 02-14-2014, 07:55 AM   #5
Ford Idaho's Avatar
Did you buy this unit new or used?
If used it is possible the owner changed one lock but not the other.
Spray some kind of penetrating oil into it and let it sit for awhile then try the key again
Old 02-14-2014, 08:01 AM   #6
I'll try that after work today and see if that works. Got the unit used but only a few months old.
Old 02-14-2014, 08:09 AM   #7
Ford Idaho's Avatar
Age notwithstanding, I changed out both locks on my 2014 due to a recall I had it about 2 months I think.
Old 02-14-2014, 08:45 AM   #8
Here is the recall:
http://www.fastecindustrial.com/reca...l%20letter.pdf
Old 02-14-2014, 08:52 AM   #9
pdeter's Avatar
My salesman told me that they are both keyed so the deadbolt key will work on both the latch lock and the deadbolt. But he also said that we should always lock the deadbolt because all people that have worked at an RV sales place would have a key that will open the latch lock but not the deadbolt. They key them this way so while on the lot, everyone can have access that needs access with only one key.
2014 Flagstaff 27RLWS
2007 Dodge Ram 1500 4x4, 5.7L
pdeter is offline   Reply With Quote
Old 02-14-2014, 08:59 AM   #10
Ford Idaho's Avatar
True and correct.
And that would include the newer ones involved with the recall.
There are options out there if you want to pony up the bucks.
