Old 02-24-2016, 11:53 AM   #11
On my fuse panel the light next to the fuse will not light if it burnt out. Sometimes the fuse filament looks ok but still doesn't work. Good luck
edcronin01 is offline   Reply With Quote
Old 02-24-2016, 03:10 PM   #12
skylilymd's Avatar
To answer your question Joshua yes I used a power probe it is a multi meter and test light combo - I tested the wires under the dinette and all the fuses test good on both sides of the fuse and none of the red lights are lit - I guess I will try and take all the fuses out and physically look at them and make sure they are all getting good contact
skylilymd is offline   Reply With Quote
Old 02-24-2016, 03:14 PM   #13
skylilymd's Avatar
Oh one other thing I noticed was that when I pulled the fuse that is labeled outside stereo my Jensen stereo and DVD player that's in front of the bathroom loses power - I also have two empty fuse locations underneath the last fuse in my coach fuse box - are those intentionally without fuses ?
Old 02-25-2016, 11:28 AM   #14
skyliliMD...I have the same model only a 2010. I had the same exact issue and when I took it back to the dealer, it was found that the 12V outlet and the 110V outlet were never connected in the first place. The wiring was there, but it was never connected under the coach at the factory.
gator2723 is offline   Reply With Quote
Old 02-25-2016, 12:03 PM   #15
skylilymd's Avatar
I have a feeling it does have to do with the wiring although my 120 outlet right there is working fine I will check underneath the couch and try and trace the wires thanks for that info
Old 02-25-2016, 12:41 PM   #16
skylilymd's Avatar
Name:	ImageUploadedByForest River Forums1456425619.045327.jpg
ID:	100385 here is a picture of the electrical panel with all the fuses removed as you can see not all the red lights light up if the fuses are bad lol - I checked all the fuses and they are good and they're connected fine once I put them all back in - both sides of the fuses are hot - off to trace the wires
Old 02-25-2016, 02:29 PM   #17
skylilymd's Avatar
Well I fixed it - wire above propane tank going into floor of coach was corroded right through - here's some pics in case anyone else has this issue - Click image for larger version
Name:	ImageUploadedByForest River Forums1456432060.956218.jpg
Name:	ImageUploadedByForest River Forums1456432080.957742.jpg
Name:	ImageUploadedByForest River Forums1456432164.271890.jpg
Old 02-25-2016, 03:37 PM   #18
Mr. Dan's Avatar
Hey, thanks for posting back. We like to hear (read) solutions!
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
2012, power, electrical
