Old 03-21-2015, 01:28 PM   #1
2015 2501 Battery holddown
Attached is a picture of the understep (house) batteries. Note where the hold down strap goes i.e. right across the fill caps. So how does one check the water level? More important, how does one even release the hold down?
Name:	150320 RV Battery1.jpg
2015 Forester 2501TS
RSiemer is offline   Reply With Quote
Old 03-21-2015, 03:01 PM   #2
My straps are the same way and slide to get the top off. Just be careful.
markangie24 is offline   Reply With Quote
Old 03-21-2015, 03:12 PM   #3
Canadian Member
itat's Avatar
Can you replace the single strap with one for each?
Old 03-21-2015, 08:03 PM   #4
camaraderie's Avatar
Suggest you replace the strap with one that can use a buckle like this or similar.... On two pieces of poly belt.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
2501, battery
