Old 09-19-2015, 09:11 PM   #71
Must be something with the left side , that's the same side mine keeps messing up on.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-19-2015, 09:16 PM   #72
papap's Avatar
I installed the airlift system. I also have a small leak somewhere. Compressor comes on for a second or so every now and then.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 09-19-2015, 09:19 PM   #73
Boso's Avatar
I have problems with both sidesClick image for larger version
Name:	ImageUploadedByForest River Forums1442715357.271214.jpg
ID:	89300Click image for larger version
Name:	ImageUploadedByForest River Forums1442715384.257709.jpg
ID:	89301Click image for larger version
Name:	ImageUploadedByForest River Forums1442715450.365618.jpg
ID:	89302. These are a few pics on the way to Outer Banks you can see the weather conditions on the background wasn't bad
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 09-19-2015, 09:40 PM   #74
I'd like to jump in with a question that's related to the airbag issue (I think), if I may. I've got a new 2015 3010DS. When we brought it home from the dealership in May, my wife was following me. On arrival, she commented on the left lean of the unit. I contacted FR by email and they indicated that I need to take it to the dealership for repair and then an alignment. I contacted the dealer, but they will only take it if I make an appointment 3 weeks out and weekdays only. I can't drop it off the night before, either, I have to be there with it. Never saw anything like the "service" department in my life. They never answer phones and they won't return calls if you indicate that you have a question. I digress.
Could this be an under-inflated airbag/unbalanced inflation issue? It handles ok with no noticeable drift, although I'm used to driving a fully loaded full size Ford work van daily.
beale1113 is offline   Reply With Quote
Old 09-19-2015, 09:56 PM   #75
Check the air pressure in the bags, there is a valve on either side of the MH, if they are not the same it will give you a lean to one side.There are other issues that can give you a lean but checking the pressure is a good start.
2014 Forester 3051s
2012 Sonic toad
Old 09-19-2015, 11:23 PM   #76
Sagecoachdriver's Avatar
back to cameras
Getting back to the cameras, my driver side camera will show "NO SIGNAL" on a blue screen. Switching cables around isolated it to the cable or camera. Working fine in my driveway. Let's see what happens on a 3 day trip at the end of next week.
When it wasn't working, I did removed the camera housing and there was nothing loose, just the camera and 2 screws holding two wires. Couldn't remove the cover on the bottom of the middle of the mirror arm. Maybe some connectors in there. But it's working right now.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-20-2015, 09:26 AM   #77
Boso's Avatar
Sagecoachdriver there are 2allen screws up in the the 2 little holes on that straight piece in the bottom the piece pops off and yes there are push connectors in there and there is 1 bolt with washer holding actual mirror on look up in the holes with flashlight u can see them .This is a pic of that piece removed with camera housing also removed and socket on bolt to remove mirrorClick image for larger version
Name:	ImageUploadedByForest River Forums1442759145.547395.jpg
ID:	89330Click image for larger version
Name:	ImageUploadedByForest River Forums1442759170.152728.jpg
Old 09-20-2015, 09:42 AM   #78
Boso's Avatar
Sagecoachdriver where did you find cables to move around I have not tried that but I don't think it would do me any good since all my camera act up just the back a little less
Old 09-20-2015, 09:57 AM   #79
[QUOTE]Sagecoachdriver where did you find cables to move around I have not tried that but I don't think it would do me any good since all my camera act up just the back a little less/QUOTE]
Boso, are you referring to the multiplexer? If so, mine is located behind the lower panel under the steering wheel. The panel just pulls out along with the OBD plug.
Old 09-20-2015, 09:59 AM   #80
If all cameras are acting up I would consider the multiplexer is the cause. If you haven't checked it it is located at the "knee" panel above the steering column. It is famous for getting tossed around and losing connection on the power side of the modulator. I would suspect the ground but it would be best to check all with a good volt meter.
My personal experience is I problems with the display cutting on/off when selected for rear camera. The dealer replaced with a new multiplexer twice but had the same problem. I called RVS for "higher" technical support. They directed me to look at power to the modulator.
Short of a long story, I had a taillight bulb that the bulb socket wasn't connected properly - basically shorting between the two filaments. It was barely detectable until I saw one of the bulbs dimly lit.
I have since changed all my Bargman incandescent to LED and never had trouble again.
Bulb shorting was a feedback on the turn signal since the multiplexer is operated by voltage sensed on each turn signal lamp.
In my opinion it is easier to troubleshoot from the multiplexer than it is going into the outside mirrors.
Good luck.
Bobby
bgilly is offline   Reply With Quote
ford
