Old 10-21-2015, 02:41 PM   #1
MNtraveler's Avatar
2401R Stabilizer Jacks (2-point)
These optional jacks that were factory installed turned out not to be mere electrical stabilizers but hydraulic Bigfoot jacks. I called Bigfoot and was told the capacity of this model is 8,000# per piston or 16,000# total. That is more than enough to lift the entire unit (11,030 GVWR, 7,720 GAWR rear). So I would think that if left/right leveling is not needed and only the rear needs to be raised a bit, these could be used for leveling. The Bigfoot rep said they don't call them levelers because they don't affect L/R balance and can't lift front to back. Any disagreement on using these for a boost on the back when needed? (Meaning more than just hitting the ground with them and stopping there)Click image for larger version
Name:	ImageUploadedByForest River Forums1445456508.542452.jpg
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 10-25-2015, 01:51 PM   #2
I:ve used mine to level (back to front) my MBS 2401R several times. Also used them to elevate coach rear to install Sumosprings.
normtre is offline   Reply With Quote
Old 10-26-2015, 12:05 PM   #3
MNtraveler's Avatar
Thanks!
Old 10-26-2015, 02:34 PM   #4
Creativepart's Avatar
I have the Ford E450 based Forester with Bigfoot Auto Levelers and I have to say after 15 years of travel trailer use and manual leveling with blocks, etc the full-auto Bigfoot levelers are one of the biggest pluses of owning my new Forester.
I love the whole RV - but if I had to single out my top 3 or 4 features the Auto Levelers would be at the top of very near the top.
Any chance you can add front levelers and get full auto-leveling?
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-26-2015, 02:42 PM   #5
MNtraveler's Avatar
Maybe, but the rear pair operate together so there is no side to side leveling with this setup. I have a lot of 2x6's in 10" and 20" sections ready to go. Click image for larger version
Name:	ImageUploadedByForest River Forums1445888543.190093.jpg
Old 10-26-2015, 05:15 PM   #6
RedLdr1's Avatar
After reading this thread I emailed Bigfoot and asked about M-B approved front levelers. Their response was:
"We are currently working on and upgrade to add two jacks to the front of your coach with a wireless control panel and a central pump. Keep and eye on our website it will be coming soon."
Hopefully a system that can reuse most of our existing parts and pieces is in the works...
Wayne and Christine
2020 Sunseeker MBS 2400Q (2019 Sprinter Chassis) with a Trekker Cap and Metallic Full Body Paint
RedLdr1 is offline   Reply With Quote
Old 10-26-2015, 05:23 PM   #7
dukeboone's Avatar
Well that's some good information!
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 10-28-2015, 04:43 PM   #8
MNtraveler's Avatar
Good indeed.
jacks
