Old 08-27-2015, 03:16 PM   #1
2401w Non-Wiring Diagrams
Thanks for the wiring diagrams for the 2401w. Can someone tell me or can we get a diagram(s) for the 2401w that shows where everything is located like the water pump, waste tanks, drains for the different tanks and etc.?
mur9335 is offline   Reply With Quote
Old 08-28-2015, 12:20 PM   #2
Class C Representative
Joshua Cavitt's Avatar
There have been some things engineering is not willing or we are not able to release. This happens to be one of those things.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 08-28-2015, 12:50 PM   #3
Okay, so can you tell me 1. where is the water pump located and 2. how to drain the fresh water tank. Thanks
Old 08-28-2015, 01:53 PM   #4
RedLdr1's Avatar
On our "W" the fresh water drain is located near the rear of the coach. Look on the bottom and you should see a white twist in plug about 6 inches in diameter. Remove it and the drain is fairly easy to reach. It took about 45 minutes for the full tank to drain after our PDI. My wife said I left a water trail for miles...
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 08-28-2015, 09:09 PM   #5
Found the white threaded cap, removed it, the chrome colored value was in line with the hose coming out of the tank. I turned it so it was perpendicular to the hose. I also pulled out a short white hose line and took off the black cap. Also did this yesterday and it emptied out maybe a glass full both times. I even turned on the pump and nothing came out. Shut the pump off and open a sink value and still nothing. It is 10 pm and still nothing. I am going to look and see how far the hose that had the black end cap on it goes up into the cavity. Any other suggestions? Thanks
Old 08-29-2015, 11:04 AM   #6
RedLdr1's Avatar
That should have done it... Why do you think you still have water in the tank? Another way to confirm it is empty is to open the fill cap and put a blow out adapter on it. Then use a low pressure compressor to pressurize the system, if you feel the air coming out the tank drain you're empty!
Wayne and Christine
Old 08-29-2015, 11:18 AM   #7
You closed the valve. Valve is closed with handle perpendicular, open with handle in line. So I'm guessing your tank is empty.
2011 Traverse LT, 3.6L, FWD
diagram, wiring
